Hi Guys,
Received my Aerosky x350 recently and need some help!
Tested it in the house just to see if everything works. When I gave it some power there is a serious lag in throttle response and it goes mental when it decides to respond (5 seconds late) as if it wants to fly at 120km/h from the get go, even if I move the throttle stick just above half way (the click). Same thing happens when I move the throttle stick back to minimum, it takes 5 seconds before it responds and start to settle down.
I though it could be that the trims are not centered, but when I tried to adjust the trims, I realized they are dummy trims! Is this normal?
I have the telemetry unit so will be able to adjust the trims etc there, but do not know what the values should be. Can anyone help?
Thanks.
Thanks.
