A quad on a budget using Amazon Vouchers!
ProfFalken
Hi all,
I'm new here and trying to get as much advice from as many different places as I can!
I've flown helis in the past (I currently own a Blade MSRx and I'm in the process of fixing up a TRex 450 clone) however I really want to make the move to multi-rotor as I'm interested in eventually doing FPV (that was part of the plan with the 450 but it's going to take quite a while to make it airworthy!)
At the moment, I'm working to a budget and I need to buy the parts on Amazon as I was given around £90 of AMZ gift vouchers on leaving my last employer.
My current parts list looks as follows:
NEEWER X-Frame
Andoer 4 x A2212 1000KV Outrunner Motor + ESCs and props
QQ Super Flight Controller
OrangeRX RX100 Satelite
Am I missing anything obvious? The only thing I could think of was that the power from the battery might need a distribution board of some sort.
Also, I'm currently working with 3s 2200MAh LiPo's for the 450, would I need to upgrade to 4s or 6s for this kind of setup?
I am well aware that this won't do any acrobatics, nor will it have anything fancy such as "return to base" or GPS navigation, however at the moment that doesn't matter as when I can afford to upgrade to a MultiWii Board or similar I'll swap out the QQ Super.
All and any advice welcome,
Thanks in advance,
Matt
ProfFalken
So from reading around and asking on other forums I've been advised to get a KK FCB as a good place to start and scale out from there.
Does that make sense?
Matt
Matt
Matt, it sure does, there are a ton of the KK boards flying and some custom firmwares depending on what you want to do.
I'm not sure which one is the latest version. I've got a kk2.0 (the one with the LED display on the board) in my box of stuff, where are you located? Pay for shipping and I'll box it up and send it to you. You'll have to update the firmware, i've never used it but have had it for at least a year.
It's this one
http://hobbyking.com/hobbyking/stor...r_LCD_Flight_Control_Board_EU_Warehouse_.html
ProfFalken
It's this one
Thanks Bartman, that's incredibly kind of you. I'm based in the UK, however I pressed "Checkout Now" about an hour before I saw this post so I've got a KK 2.1.5 enroute to me.
The good news is that I'll have the frame and the power distribution board with me by Thursday and then the other stuff should arrive from China in the next couple of weeks.
I'll post updates here as I build this.
Thanks again,
Matt
