SFC76
Doing a basic build I ran into a few issues I can't quite solve without a little help.
I just want to get to the maiden flight, and when I'm happy with the build, I am planning to add GPS (or should I add it right away?)
This is my setup (I'm leaving out the obvious like frame, motors and props):
- Crius AIO Pro v2, running on MegaPirateNG 2.8 R3 (for now, soon 3.0.1 R4)
- EMAX 4in1 25A ESC, running SimonK
- Corona RP8D1 35 MHz
- robbe Futaba FX-18 35 MHz (Mode 2)
First issue I encountered was with calibrating the ESC's. I calibrated them by connecting each ESC directly to the throttle channel of the receiver (ch.3).
Oddly enough, the throttle is reversed while it is set to normal in my transmitter (full throttle is stick up). I changed it to reverse in my transmitter, and works like it is not reversed after calibrating
. I can live with it for now, but has me pondering what can cause this.
Second issue is that I don't see the green bars in APM move in the receiver calibration step. I do see the green bars move in the failsafe section (and to my amazement, throttle shows as reversed there?!?
Third issue is that after arming the idle speed seems way too high. It responds to stick input (making it more confusing I don't see stick response in APM), but shouldn't idle speed be very low RPM if not full stop?
I haven't been able to find a setting for idle speed yet, but I will search deeper in MPNG when I have the time this weekend.
I do have a PPM encoder, but it should be of no use on this build since my Corona receiver is PPM (correct me if I'm wrong).
Any help would be much appreciated (especially the first issue, it's driving me nuts)
Cheers,
SFC
Cheers,
SFC
