gtranquilla
RadioActive
A couple of my slightly used older motors had some run-out and were hard to balance so I replaced them with brand new. But during the first few test flights I noticed that older motors, M1, M3 and M6 were running hotter than the others and noticed some roughness in motor rpm during MR hovering. So I replaced M6 and did another test flight. Hovering seemed to be much smoother but M1 was still a bit warmer than the others and there was still a slight bit of roughness while hovering..... so then I replaced M1. On the subsequent test flight the MR took off in the direction of M1 for about 50 feet then flipped into the ground....... which seems to suggest the replacement motors was worse than the previous.
I don't think this is an ESC issues as they are all new, configured the same way as always with LVC set low as possible and with battery type as Nixx and bench tested.
The only other thing I can think of that changed in my standard Hex design is that I moved the WKM firmware up from 5.20 to 5.26..........
Are others having issues with 5.26?
Motors are Turnigy Multistar 22 pole 420 KV 4830.
ESCs are Turnigy Multistar 45 amp OPT.
