6mm to 5mm prop spacer
FlyEYE
I came a across a thread somewhere in the past where there was a link to spacer you can put over a 5mm thread so you can use 6mm drilled props. I gave up trying to find it so... anybody know where I can buy one? Any other secrets to doing so besides shrink wrap? Thanks.
FlyEYE
Just bumping this up, surely someones encountered this. I`ve found some brass pipe that has an OD of 6mm and an ID of 5.1mm, should work but I`d rather not have to cut pipe if I don`t have too.
FlyEYE
I used 2 layers of what I think was 6mm shrink wrap. Works great, the only issue is I wanted it to be easy to switch props. I'll post if I ever come across that spacer again.
