Patscherpofel
I was too optimistic with the AUW of my Octocopter project
it flys fantastic on 6,5kg but with a bigger camera I will be at around 8kg, so unfortunately I have to update the entire drive
if you are intrested in the following items as a set or alone please PM me
if you buy the entire set I can give you the best deal...thinking around 20 to 30% under the price I paid
let me think about it as soon as there is interest
8 -AXi 2814 22
bought them here
http://www.electricwingman.com/axi-droidworx-281422-motor.aspx
-the bells are balanced (even Axis need that)
-the cables are cut to around 35cm and have 3,5mm bullet connectors
-6mm prop adapter
-total run time...around 4 flights only
8 - Xoar (presicion paired) 13/6.5 (not 16 inch...mistake in the thread topic)
-also balanced
8- Hobbyking F30A
-simonk flashed on the newest FW
-plasti dip under the shrink wrap to prevent failure when its really cold
all in all this is one of the best comobos money can buy these day...I have been using this setup on other copters too for many month, never had a single problem
check out the stuff in action
shipping from austria
8 -AXi 2814 22
bought them here
-6mm prop adapter
-also balanced
8- Hobbyking F30A
