mbsteed
aerial video centric
A while back I reported that I had given up on the WKM - it had crashed for the 3rd time. It had flown fine for the first 10 seconds after it was built the first time but then it went out of control on each rebuild. Not cheap replacing motor mounts and arms on our Droidworx ADH8. Well, I rebuilt it one more time and decided to give it one last go. One change I made was that I removed the Futaba S-bus converter for my Spektrum system (we wanted to use that because that would have freed up the camera gimbal controls on the ocoto). The second change was as follows: When I powered it up for the first time one of the motors would start up and then stop and power up again. That had never happened before so I replaced that ESC entirely. ...seemed to fix that problem.
Took it out for a test flight today and all went well - what a relief!!! Previously it would go totally out of control. Not sure wether the problem was the S-bus converter or the ESC (I suspect the ESC) but I will probably never know because I don't dare try putting the s-bus converter back on. It is amazing how frustrating one small problem can be when you are dealing with so many variables on an Octo setup.
We are now looking to add a photohigher AV 200 gimbal and Skyline stabilization system. Any suggestions or warnings about those?
