Hey guys,
Today, I started getting rid of MK BL controllers officially by the help of Abusemark's I2C to PWM converter and some different ESCs.
Mikrokopter's BL controllers work very good until you reach its limits. There's no need for programming, it's almost plug&play. But the limitations are also quite annoying:
* Any I2C error means total crash.
* It needs Recom modification for 5S, additional modification for 6S (If you want to use the power from Lipo directly) on the FC. Supplying direct power from Lipo will helpyou to see the correct V and amps spent over the telemetry. Otherwise, you can supply power with BEC so no need for any modification.
* BL Ctrl's get hot even with 5s. Reaches the temp limits with 6S at 10-14Amps as far as I read. The current ve S limitation doesn't let you to use some powerful motors to lift a camera like Red Epic.
* It's expensive.
vice versa. We know all these, right?
I'm getting rid of BL Ctrls mainly for using 6S and some beefy motors.
So what I have in my hands:
* I2C PWM converter
* Turnigy Plush 40A ESCs (I flashed them with BLHeli firmware since they're based on SiLabs chip. )
* HK F-60A ESCs (Flashed with Simonk)
* Red Brick 70A ESCs
* Tiger MT2826-KV 550
* Tiger MT2520 - KV400 motors ( Still on the way).
* Gens Ace 6S 10000 mAh batteries.(Still on the way). Will also test some 8S batteries.
Why do I have so many ESCs?
I will also test Castle Creation ESCs. First I will proceed with nicely flashed SimonK based HK and BLHeli flashed Plush ESCs.
I bought these ESCs long time before; they all have place to fit. Plushes for Hexa, HK F-60A for heavy quad and Red Bricks / CC ICE for Octo.
So this is the first message; the process will take some time (I believe 3-4 weeks). Im not in a hurry. I'll post my findings and on-board footage here as soon as I start the building.
* It's expensive.
* I2C PWM converter
