the flashing light still happens with it turned off, it just doesn't try to take a dirt nap
What charger do you have?
what it is when you read it on the ground means nothing to what it is in the sky
heres an osd and what a good pack looks like underway. See how when the amps go up the voltage goes down..... thats a pack with IR 3-4mv a cell
saw a 14.2 and thats a 4000 mah pack 1500 mah in
now heres a crappy pack. starts out at rated voltage 1600 mah into 6600 mah total.... by 1:30 it's 5200 into 6600 and 12 volts...... thats a pack with high internal resistance. It's invisible, it's a number a charger like icharger can tell you. it is also seen in voltage checkers to a degree in the form of uneven cell voltages. it'll really start getting different the worse they are. one flight i'll get it 5-8mv a cell, next flight it'll run short on me and i'll take it deeper into hell and that's all she wrote, 2x 3300 4s packs ready for the garbage
they have a normal if everything is perfect life span of 2 years or 200 cycles. if you store them over 40 degrees it'll naturally die off 2-3% a month, if there stored in the fridge, it'll drop to more like .1% a month, if you get em 90 degrees while stored it'll drop 5-20% a month depending on the cells quality. Only thing worse than hot is full voltage and hot. If you have an icharger, look at your manual and read what you got for numbers to me, otherwise call progressive
I do remember something like this as a firmware problem, but it was a firmware that didn't load right or something. I'd look at my packs good and hard first.
those packs in those videos above were all 16.8 when they left the ground
