DJI OSD - Video Output Connector Voltage High
RotorTalk
No Longer Active
Prior to wiring this unit in I decided to check the voltage on the video output ribbon which has twin POS and NEG wires (for twin TXs?).
I connected the OSD up to a charged 4S LiPo and read 16.65V ... This is too high to feed my 5.8Ghz 200mW Tx which like many others uses 12 to 15V
Anyone got any ideas?
RotorTalk
No Longer Active
OUCH - its a pass through connector. I connected a 3S and the voltage matched it exactly.
I find this a bit surprising - a 12V supply suited to external cams would have been nice. Will just blank these wires off.
RotorTalk
No Longer Active
I've got the OSD working but only with a Samsung NX200 camera which has its own power. 11.3 V isn't enough to power my 12V Pixim SeaWolf FPV camera (I got a bit of B&W flickering initially).
Does this mean that none of the power outputs will power a 12V FPV camera?
when this was mentioned last week i knew it was gonna screw things up......
airwave vtx use 2-4s lipo power,,,,,, the 11.2 or whatever would be fine, but it takes an immersion vrx like uno or fatshark goggles receivers
Made for fpv my ***.......
