So I'm trying to set up this fail safe still.
I have the enhanced failed safe method in WKM assistant set up to Intelligent Go Home.
In the Devo 10 I can't figure out how to get it set up for fail safe. Here is exactly what it says in the manual:
There are two possibilites for use if the transmission signal is under abnormal condition. The first one is to lock the last action data received; the second one is to execute the pre-set data which is pre-set. The default setting is Servo Hold.
Setting method:
Press ENT to enter the Main Menu, and then press UP or DN to move the navigational mark to select Function Menu. Press ENT to enter the Function Menu then press UP or DN to select Fail Safe and press ENT to enter the Fail Safe interface. Take the item Elevator as an example to explain.
Press UP or DN to select Elevator on the Fail Safe interface, then press R or L to change the status of Servo Hold into Fail Safe(if you want to keep Servo hold status, there is no need to re-set). There is a expanded sub-item blow.Press UP or DN to select 0%, then press R or L to increase or decrease, respectively, the position amount which centers on the neutral point of servo. The available value is 125%, respectively. 0% is the neutral point of servo.
The setting methods for other channels are same as above. Press EXT to exit after finished.
Note: checking whether all the actions when fail safe happened are correct, is a must after the setting is finished. It is dangerous to use full throttle, especially after fail safe taken place.
So that's what it says. Obviously I do NOT want to do this incorrectly as it could result in a VERY costly crash. The switch I have setup for my "go home switch" is rudder d/r, which is not in the Devo Fail Safe menu as being available for fail safe.
Any help is greatly appreciated.
Tom
