Ok, I've researched the internet, research this site, tried everything and then some but my problem is still nagging me. So after spending a full week trying to fix the problem on my own, I have finally given up and am going to ask for some help
I'm converting a Xaircraft X650 FC to a Wookong M flight system. I am using Turnigy 25A Esc with Input Voltage of 2S-4S and BEC:Linear Mode 5V / 2A
My motors are Turnigy 28-26
I am using a Spektrum DX8 with a AR6210
I have programmed the esc's and I believe they are ok, my settings for each are: Brake: Off, Cut Off: Soft-Cut, Cut-off Volt: High, Start Mode: Normal, Timing: Middle, Cell: Auto
I have also binded the motors to the AR6210. I have pulled the red wire and plugged into the FC. I have re-checked every connection atleast 6 times. I have re-checked the esc's to make sure they held the program. But the second I hook the lipo up, I get a constant beep. Three of the motors have a slight jerk when the battery is plugged in. It sounds like its only one esc beeping, but if I listen closely it sounds like them all. So my question is, what did or have I've done wrong, what am I missing?
Thanks in advance
Shawn
Thanks in advance
Shawn
