Flexacopter -----The Making of an octocopter "KRATOS"-----
holco
The numbers say it all Chris ;)
With the Kratos we need about 1200 grams lift for each motor.
holco
Test of a new Plettenberg Orbit 15-34 with the Mejzlik 15x5 propeller.
This combo had a 5 minutes test run on 1200 grams, with an ambient temperature of 26° the motor reached a max temperature of 48°, so in total 22° above ambient.
Plus/minus Amp's draw by different weights and config's,
Hexa AUW 4Kg: 15,9A
Hexa AUW 5Kg: 21A
Hexa AUW 6Kg: 26,2A
Hexa AUW 7Kg: 34,3A
Octo AUW 7Kg: 30,4A
Octo AUW 8Kg: 35,6A
Octo AUW 9Kg: 42,4A
Octo AUW 10Kg: 50,4A
Octo AUW 11Kg: 56,8A
Octo AUW 12Kg: 66A
Octo AUW 13Kg: 73,6A
Octo AUW 14Kg: 83,2A
ChrisViperM
+1 :tennis: :tennis: :tennis:
Your posts are always great and a wealth of information.......would just be great if any now and then people would just simply say : Thank you.....
Chris
boranup
Agree with Chris I am in awe - never seen such amazing builds and quality - Im always waiting for the next post just to see what the latest development is!!
Keep up the great work!
holco
Thanks guy's,
Its much appreciated to get some positive reaction so we know people are interested ;)
Mario/Pieter
holco
Conversion of the pan to brushless,
Short mirror test,
ChrisViperM
Hi Mario
I have to officially complain......why is there no infos about the landing gear in this thread which I saw on Facebook........:02.47-tranquillity:
Chris
PS: Build thread will be finished this week....I promise
holco
Hi Chris,
Your absolutely wright but I needed to find some time to shoot a video of it ;)
Teamflail
Wow, I am in aww. Been reading this post for a bit but finally watched the vid. That is truly impressive. I need to upgrade!!
ChrisViperM
Very nice......love it.
Just a few questions: Would it be possible to make that part, where the DJI landing gear is attached , in black....?
I am talking about this one:
I guess, in case I want to fit a Zenmuse to the Kratos, the space underneath the LiPo cage will not be enough, meaning the legs will be too short. First I was thinking of just making the landing-gear booms longer, but than the weight of the copter might be too high up. Another option I could imagine (if someone want's to use a Zenmuse) is to remove the LiPo-cage and mount the LiPo's on top of your landing-gear carbon plates.....???
I know....you can't have it all :tennis:
Chris
holco
Black isn't a problem Chris.
Your correct that when you want to use the Zenmuse you need longer 25mm carbon booms (we have them on stock) on the leg's, but when you lift of the legs on some blocks during the startup calibration
of the Zenmuse you don't need longer booms ;)
Other mount systems that don't do the compleet 360° roll calibration like the Zen will just fit with the standard length booms.
Because the weight of the battery's are part of the wiredamper system you don't want to move them to a other place.
Mario
