Flexacopter -----The Making of an octocopter "KRATOS"-----
holco
After our successful Flexacopter hexa ( http://www.multirotorforums.com/showthread.php?2218-Flexacopter-The-Making-Of )
We are introducing our new "costs no limit" octocopter ---KRATOS---
The objectives are,
Multiple system use, such as, Mikrokopter with the V2.0 ESC's / DJI Wookong / YS-X6 / and others.
Octo setup, + and X mode.
Max 6S setup with two 8000mAh lipo's for long efficient flights, with adjustable battery box.
Easy removable 20mm carbon arms with integrated power and led plugs for easy transportation.
Carbon big 250mm frame and carbon motor supports.
ESC's frame and boom mount options.
Aluminum 20mm boom clamps for rigid mounting of booms and motors.
Compact Wire Rope Isolators, modular system for 2Kg (Canon 5D) and 4Kg (Epic RED) camera's.
Plug and play for the CS 3 / PH AV-200 360° pan mounts
Reliability and good looks!!
Muhkuh
Do you know when Kratos will be ready? This is just what I am looking for...as long as it isn't too pricey.
3dheliguy
That thing is going to be in the Thousands I bet..Ugh looks so cool already tho. Man Flexacopters are pretty nice frames.
holco
The mount for the Kratos, the setup will be for the RED EPIC.
And the 3 axis stabilisation system we ordered for it,
holco
De Cinestar 3 mount is ready to mount under the Kratos :D
Balancing
Total weight with the Sony 730
The total picture
Except for the lipo all wiring insite
