I own a F550 with Naza flight controller and all stock ARF equipment. My TX is a DX7 and AR7000 RX. I am an avid heli guy but new to mutli's.
So far on my hex I have around 20 flights and they have all been perfect. Once I got the gains all set it has flown like a dream. Until yesterday! :upset: I was about 4 feet off the ground doing a nice hover filming with my POV. Wasn't even touching the sticks. Just letting the bird hover in one spot on her own. All of the sudden out of no where it goes crazy and flips onto its back hitting the ground. Luckily I wasn't very high off the ground so no damage occured. Needless to say I was baffled. Exactly 4 cuss words came spewing out of my mouth. I will spare you their content. I did a number of checks to make sure something had not come loose or changed mid flight to cause this. Below are these checks I performed.
-I went into the NAZA assistant software to make sure nothing had changed in the NAZA setup or TX setup. Everything was fine. Nothing had changed. Keep in mind this bird has flown perfect till now.
-I checked ESC to motor connections.
-I checked ESC to NAZA connections.
-I checked RX to NAZA connections.
-I checked that all my prop nuts were tight.
-My NAZA is dead center in the frame and pointing forward towards the red legs.
I decided to try flight again in some soft grass by my house and it did it again. I am able to get it up for a second or two then suddenly it looses control and flops on its back. Its the strangest thing. Makes me wonder if something within my NAZA is toast?! Does DJI has good customer support or warranty or will they just shun me away?
Please help. I am at a total loss.
Today I will make a video of what is happening to post up here...
