Hi everyone,
I'm mounting my GPS unit tonight and I've got a few questions. Any help would be appreciated.
When you get the three-position switch set up, I understand that the top position should be off, and the middle position should be position hold but in the come-home position should the position hold box also be checked along with the come home box in the set-up client?
When doing the calibrations after installing the GPS, is the USB cable to be plugged into the GPS board or Pro board for the temperature compensation test? The .pdf guide makes it sound as if the USB should be plugged into the GPS board but I'm not getting any results with the temp comp test that way.
That's as far as I've been able to get. If it can be sorted out tonight it'll all be flown in the morning. With four days of rain forecasted I doubt I'll get much farther this week.
THanks,
Bart
THanks,
Bart
