I am trying to setup my quad but I can't get it to work properly. I wired the S-Bus port on a R6203 receiver to the X2 port of the NAZA controller and when I go to the assistant and select D-Bus everything seems to be working. I can calibrate the transmitter controls and see all the auxiliary switches actuating.
When I then disconnect the NAZA from the computer, reboot and try to fly it I get the normal startup blinking up to the four green lights but then a rapid yellow blinking kicks in. From the manual it seems it is because there is a loss in transmitter signal but the receiver has a green light on it and the servos I connect directly to the receiver work!
So if the S-Bus connection is proper, given that the assistant works flawlessly, and the receiver has signal from the transmitter, why is the NAZA controller complaining?
Thanks for your advice.
