GeorgeM
@Mombasa, Remoteworkx, Rene.M
Must say that Pan is working perfectly over here. I'm on v56_76 ,as was published on the 29th of April.
Just want to make sure that in order for this to work well, AUX 1.. ie the GotoHome / E-Stop function MUST BE CENTRAL OR TOWARDS THE E_STOP.
As you know this switch is a toggle function, so that it works on both 2 AND 3 position switches ( not everyone has sophisticated radios on Gimbals )
E-STOP is the Toggle Function. Goto Home is always Active when this channel is parked at Goto Home Position.
If this function channel is' parked' on GotoHome position, then.. for sure... Picloc will try to go to home position and keep to it. ( this includes camera facing south..or north depending on how Picloc is oriented in your mount.
( it's all a question of servo reverse and gain at the end of the day !! )
Next... Magnetometer fix.
This is a real head scratcher....
@Mombasa... Prepare your vote... File Load Save as is working here.. just need to iron out 2 stubborn values that have made up their mind to escape the 'loading' procedure.
