I have my new build Hex in the air and doing pretty much what its meant to do, which is no mean feat given the abuse it has had at my hands!
So, I'm really looking to upgrade the motors now as the motors I have are cheap Chinese made things, and I am not convinced they won't let me down. I have restricted flight to my own 1 acre property so far, with a few excursions into the neighbouring farmers fields when I have felt adventurous enough. But I am waiting until I complete my OSD additions and get more proficient with flying before attempting FPV with my goggles. I want to have a good level of confidence in the components before this machine is allowed to fly distance.
Earlier today I received my carbon 1045 props, which I bought as an upgrade. I had a minor tumble on landing and a prop dug in to the ground. Being harder than the usual plastic blade it didn't snap, but the rotor and blade detached from the stator, as the circlip retaining the driveshaft gave way. This has got me concerned about the quality of the motors, although they have been robust so far.
So, my question is, who are the motor manufacturers to consider, and who to avoid. Also what spec should I go for based on 2 things:
1, better flight time. (I can't go higher than a 10" blade which I currently use.
2, Ability to transfer to a larger frame in due course, probably a Tarot 680 with a 12" blade.
My spec as follows:
Carbon 550 Hexacopter.
1045 blades
2212 920kv chinese motors.
30A SimonK ESCs
Pixhawk FC
Neo 8m GPS
Taranis X8r and X9D combo.
Transmitter with Fat Shark antenna
2 axis gimbal and Gopro Hero 3
Few other pieces of light equipment such as 12v and 5v BEC and batt monitor.
All in about 2500g AUW with Turnigy Battery (4s 8000mah)
I also use 4s 10000mah, 4s 8000mah and 3s 5200mah
I can get between 10-18 minutes flight time depending on battery, but thats without pushing it too hard.
I would like to use a motor that is more economic and reliable if possible.
As usual any advice much appreciated.
My spec as follows:
1045 blades
30A SimonK ESCs
Pixhawk FC
Neo 8m GPS
