ANX james
Hey all,
My issue is a single motor that will slow and stop after about a minute of hovering.
My setup:
-SkyHero Spyder 1000mm frame
-Wookong-M autopilot (just upgraded FW to 5.26)
-x8 configuration (just upgraded from x4)
-power is one (or maybe a second if needed) 8000 mAh 5s LiPo
-ESCs are 40A with SimonK firmware
-Motors are t-motor mn3515-15 kv400
Other details:
-After I land it, I can hear the motor beeping quickly for a minute or so and then stops, after which I can't arm it with the others. I'll power it off, and then 10 minutes later I can arm it with the others and it acts like it's ready to fly.
-I've tried replacing the motor and it does the same thing.
-Re-calibrating the ESC (setting throttle max/min) won't affect anything.
-Problem only happens after hovering for a minute or so; not if just on the ground running, nor if props are removed and I run the motor directly from the receiver. (I've changed out the ESC while running directly from the receiver, and I can't get the motor to fail as it does while hovering.)
Puzzling. Thanks for your thoughts, all.
My setup:
Other details:
