SchrodingersCar
Inline with @SchrodingersCar 's 'Humbled' thread, I'm struggling with the basics of getting a 1000mm-ish craft in the air.
Oh boy, my name is already becoming synonymous with failure!
Shawn, did you reuse some holes for your clever halved-battery-plate mounting? I unfortunately don't have a local source for standoffs, but I do have a handful of 10mm and 12mm aluminum in case that would serve the purpose.
	I think the KDE ESC's are good; what is lacking is the APM documentation. I can't imagine there aren't others running this combination, but maybe they just know what to tweak. It's such a simple thing, the PWM range from the radio and how it is ultimately delivered to the ESC's, but it's definitely not sufficient to simply set the min/max values in the Mission Planner advanced parameters.Man I give you kudos for perseverance. Glad you got it going but please be careful with that spinning prop situation, maybe take some leather gloves next time. I just made a mental note - don't use kde esc's. Definitely would ask Patrick at this point.
The extra 2+lb down there made a huge difference in the feeling of balance.
Wow. Glad you didn't get more seriously injured while reaching in with spinning props!
Also, KDE escs do not need calibration. They are pre-configured from the factory. Have you spoken to Patrick yet?
OK I tried it. I've got the Taranis locked down to 1100-1900us range on throttle, redid RC calibration, and tried arming. The motors do not spin upon arming, however I was able to add a few clicks of throttle just to get the motors to spin, then disarm to confirm they stopped spinning. I think I am close.Agreed, I did not think the KDE would be the issue. I have used them successfully with the Taranis for a while (but never Pixhawk). And i have used the Taranis with Pixhawk (but never KDE) so it seems the specific combo you have is the issue.
