Discharge plug?
Carapau
It might be that the power leads come without any plug on so you will have to put your own on such as EC5, XT150 or whatever.
I was looking at these batteries. http://www.genstattu.com/tattu-25c-10000mah-6s1p.html
They have the typical jst balance plug and highlighted in red it says "discharge plug not available". What is a discharge plug? I thought most chargers discharge thru the main plugs. Also, is there a chart which shows me how to select the proper connectors? Thanks.
Yes, in RC hobby area battery chargers discharge. But in UAV professional area, there is jst-xhr balance connector and discharge plug, but different customers use different discharge plug, like XT-60, XT-90 or XT150&AS150 dji plug.
The reason why we use discharge plug and balance connector is that balance connector could help to remain the same internal resistance, voltage and capacity of each cell (if 6S, that's 6 cells). In this case, the battery could have better performance and longer cycle life time.
Below is the JST-XHR balance connector. Next time I will post more pictures about the plugs.
regards,
Anna
