SynDrones X8 Heavy Lift Build
Hey Guys,
Recently I started rebuilding our SynDrones X8HL frame into a bigger heavylift rig. I had built it once already with the A2 FC, KDE 4014-380KV motors, and KDE 55+Amp ESCs but the A2 failed and caused a crash. I decided to rebuild without using the A2 and went back to the trusted MikroKopter FC which I have been flying on our smaller Cinestar 8 frame for over 2 years without an issue.
Here are the specs for the new build:
-SynDrones X8HL Frame (best frame out there honestly)!
-Mikrokopter 2.5FC w/Navi Ctrl and GPS
-Herkules III Quadro XL (x2) ESC system
-KDE 5215-435KV motors
-T-Motor 18x6.1 CF Props
Here are some pictures from the build.
attachment.php
attachment.php
These motors are HUGE! I had to modify the motor mount slightly so the hole on the bottom would clear the screw that helps hold the shaft collar on. I don't have the large motor mounts for the frame since originally I was just using the 4014s.
attachment.php
attachment.php
Because I am using 2 of the Herkules boards I have 4 power leads coming out of them. I only am flying with 2 batteries so I merged them together so I have the each battery power both boards. To do this I used 2x 5mm bullet connectors and soldered a power lead from each board into the LONG end. Then I soldered them together with a single wire coming out from the connectors and heatshrank it all together.
I stacked the boards ontop of each other and the way they are wired to the motors the top board powers all the top motors and the bottom powers the bottom motors. With the mixer setup If I loose one board inflight I loose the top or bottom motors and not 2 motors on one boom. I think with the total weight I will be flying it should fly on 4 motors! I will be testing this soon.
**Side note, Herkules does offer a Octo XL board which has 2 quad power boards mounted to one heatsink. Because I live in Phoenix and have to fly in really hot weather I opted for 2 Quadro XL boards so I had 2 heatsinks which will keep things cooler.
attachment.php
attachment.php
Here it is completed just before the maiden. I love how clean of a setup this is with the Herkules boards!
During my initial motor tests I was getting a very strange sound coming from the motors. Here is a video to show what it was doing:
This concerned me as I had never heard this before. I sent an email to both Andreas from Herkules and Patrick from KDE to get their opinion. Andreas emailed me back first saying this was normal and was because of the "Active Freewheeling" feature of the Herkules boards. He noted that once you add the props to the motors so there is a load on them it would go away. I added the props and sure enough it sounds normal again. For those of you who are not familiar with the "Active Freewheeling" here is the description from Herkules website:
"This is a method to dramatically reduce the power loss of the power MOSFETs. Another positive is that
the ESC can decelerate the motor actively by directing current back to the battery (regenerative braking).
With AFW ON, the motor reaction time to setpoint changes is reduced and the multicopter flight control
loop gets faster and more stable."
Today I received an email from Patrick at KDE and he wasn't sure of the sound. Once I explained to him what it was he said it made sense.
By default the Herkules ESC system comes with the timing set to 18*. Because of the high-pole count of the 5215 motors I changed it to 24*. I also had to program the ESCs so they had the correct motor address that the Mikrokopter FC could understand.
After that it was time for the maiden. The first flight I did without any payload. It was just the copter and 2x 10,000mAh 6s batteries from Tattu. Ambient outside temp was 100*F and around 50% humidity. I hovered around for a few minutes to ensure how it was flying. With the initial PID settings on the MK FC (P110, I120, D10, Gyro-Comp: 55, Gyro Stability 5) the copter was flying beautifully! I flew around for 15 1/2 minutes and used 17,000mAh out of the 20,000 total. Motors weren't any warmer then what they were just sitting in the sun before the flight and the Herkules boards never went above 50*C. This was mostly hovering around with a few, almost full throttle, climbs. This thing climbs like CRAZY!
attachment.php
After that test I decided to load it up with more weight then I would probably be flying. I added 16.5lbs of payload and took off. Total AUW was 34lbs with the 2x 10,000mAh 6s lipos. The way the payload was strapped on made the copter unbalanced, as you can see in the picture, and wasn't supported well so it swung around a lot. Because of this I only hovered and didn't do any movements. I stayed in a hover about 10ft off the ground for 5 1/2 minutes. There was no wind and no airflow over the motors or Herkules boards. Even at this weight and with the ambient temperature now around 105*F the Herkules boards didn't go above 80*C. This was only on 2 motors since it was off balance. The rest of them were around the 65*C mark with an average for all at 68*C! This made me VERY HAPPY as I haven't been able to fly anything heavy before without risking them overheating. Total current draw was 146-150amps
I will be doing more tests in the next few days. We just had a crazy storm come through so I couldn't fly today but I will be flying tomorrow and doing more tests. Overall I am EXTREMELY happy with how the rig is performing.
I will update this thread with more info as I test.
Josh
Cheshirecat
Wow that is a monster.
The Herkules is a great bit of kit and the support Andrea's gives is superb and it always appears to be just cruising, i don't have to fly in 100 Degrees fortunately but my rig also never gets anything other than barely warm with ambient at around 75F. usually between 25 and 30 Degrees C during Flight.
Have you implemented the datalogging and telmetry with the MK ?
Yes I have full telemetry with the MK controller. I am using the graupner mz24 radio so all the data gets feed back to that.
Just finished the test with the EPIC. I'm slightly confused with my results... my flight time was just over 6 minutes. However the copter is only reporting using 11,000mAh out of the 20,000 total available? These batteries are pretty new still and have been taken care of. Also there really isn't that big of a load on them. Is there something up with the voltage reporting that the copter is giving me back? Here is the log file:
Flight date: 9/10/2014 1:33:55 PM
Flight time: 1:33:55 PM.4 - 1:40:04 PM.6
Duration : 369 secs, 00:06:09
Batt. time : 368 secs, 00:06:08
Start Location : +33.6054769 / -111.8632682 @446.5m
Elevation(GPS) : -7.106 3.3 14.631 m (min/avg/max)
GPS alt. (raw) : 439.725 449 461.462 m
Altitude(Barom.): -0.15 7.42 16.65 m
Vertical speed : -1.88 -0.04 2.62 m/s
Max speed : 17.6 km/h
Max target dist.: 0 m
Max distance/LOS: 31.5 m / 32.2 m
Sats : 7 6 8
Voltage : min. 21.7, max. 24.6 V
Current : 0.5 115 161.8 A
Wattage : 11 2617 3656.68 W
Capacity: 11752 mAh
Motor1: 1.7 15.3 25.1 A Temp: 39 52 59 °C
Motor2: 1.2 13.9 23.4 A Temp: 40 55 61 °C
Motor3: 1.2 12.7 20.9 A Temp: 37 53 59 °C
Motor4: 1.4 12.3 18.5 A Temp: 38 53 59 °C
Motor5: 1.9 14.2 23.4 A Temp: 37 58 66 °C
Motor6: 1.7 12.8 23.4 A Temp: 37 58 68 °C
Motor7: 0.2 17.2 25.3 A Temp: 37 61 69 °C
Motor8: 0.0 16.8 25.3 A Temp: 37 59 69 °C
Magnet Field: 84 93 105 % (ok)
Magnet Inclination: 52 57 72 deg
Errors / warnings:
FC-Flag "LowBat" (5) occured 329 times!
As you can see the copter is only seeing 24.6V as max voltage even though the battery was charged to 25.1V. I'm only pulling an average of 115amps which equates to 57.5 amps from each battery. These batteries are 10,000mAh and rated for 25c so effectively I should have 500amps max without any issue so why would i have such a huge voltage drop when I'm only pulling 57.5amps?
Thoughts? Next time I will put a voltage alarm on one of the batteries and see if that goes off at the same time as I get the low voltage alarm on my Tx (It's set to go off at 22.2V or 3.7V per cell).
I'll post the pictures and video soon.
Josh
min0nim
I was testing battery and flight times last weekend on my build.
I was triggering my 3.6v (cell monitoring) alarm very quickly. What I found was the batteries were stabilising at around 3.58v in the air, before dropping off quickly at 3.5v.
Once on the ground, they'd return to 3.65v.
I'm usually landed well before 3.5v per cell, but the heavier build seems to be working the batteries slightly differently.
Hey Everyone,
Thought I would give another update after flying the copter a lot lately (about 55-60 flights now in the last 2 weeks).
First thing, IT FLIES BEAUTIFULLY!!! I mean best flying machine I've ever flown. It is super stable, even in strong winds (did a test flight in gusty 20+mph winds with our Canon 1DC on there for weight and it just moved around the sky a bit. No shaking, vibrating, ect. Very predictable and I still felt safe flying it.
I will never need to worry about the copter overheating again. We did a job about 2 1/2 weeks ago flying an EPIC with heavy Zeiss cinema glass and it was around 109-111*F outside for ambient temps with no wind. Highest temp I saw after looking at the log files was about 55-60*C. Motors were warm but not hot. I have noticed, and after talking to a few other people, that the KDE motors tend to run warmer then other motors. They are the same temperature no matter what my payload is, from nothing to EPIC. There is only a few degree difference.
The only problem I have been having, and I'm not the only one, is my AH only works when hovering... it holds perfectly in a hover but as soon as I fly forward or backward it starts to drop then if I go back to hover it climbs to where it should be. Another guy who is having this issue has been talking with Holger to try and figure out what is causing it. We have tried both the 0 for throttle setpoint and 127. Both behave the same. I never fly with AH so it isn't really an issue for me but it would be nice to have I guess.
Oh and this thing is FAST! We flew it faster than I've ever flown one before and it still had more left in it! Even at the higher speeds it was still perfectly stable. The climb rate on it is insane as well. I've only done a full throttle climb once and it was scary how fast it climbed. Went from 12ft to 81ft in 1.2 seconds!
Last thing is flight times. With our 1DC we get around 11 minutes. Thats landing when batteries are reading 21.3V. With an EPIC we get between 8-10 minutes depending on how it's setup.
Josh
Mrtarango32
Did you talk with Andreas about running two quad boards instead of one octo board? It makes sense but curious to see if it performs better or what? Thanks. Great build.
Yes we spoke a lot before I made that decision. Because of the motors I'm using and where I fly, Phoenix AZ, also the payloads I would fly we determined 2 could handle the heat better.
Racerx1962
I assume the motor mounts are the same thickness? As for the main plate thickness, that seems to be a bit much. Most CF plates are 2mm; I would think that the G10 at 3.5mm is substantially heavier than CF. Why then G10 over CF? I'm curious...
jfro
Aerial Fun
A couple posts back he said something to the effect it's the best and fastest flying MR he's ever had. For a large MR, that's outstanding. I for one wouldn't question any part of this build. Looks like he nailed it. Good Job.
For something that heavy, I'd be use thicker G10 plates also. The extra oz or two for strength and stability is obviously working very very well.
Main reason is its cheaper than CF. Also where it gets hot outside, like it does here in Arizona, the white g10 doesn't get hot at all which actually helps keep electronic Temps down.
atomkind
Hi,
I´ve been reading your thread and saw that you have kind of a similar problem as me. I also have a big X8 flying the epic. In my case a 15kg machine with A2 and Herkules Okto XL III. When I hover in ATTI mode it holds height perfect, but as soon as I fly somewhere I loose height. As soon as I stop the copter gains the height it lost.
As I am flying the A2 (also tested with wookong) I wonder why we have the same issue. Maybe it´s the hercules? Did you solve the issue?
I will switch to the mikrokopter electronics too for redundancy and to hopefully solve this problem.
Greetings
