Sorry, I should have mentioned I live in Australia. Autonomous flight is not legal here. Pilots must be in total control of the copter at all times and LOS is required. It is possible to get exemptions from CASA but it's a hassle. I'm actually a big fan of autonomous flying but until it's _much_ more reliable I really think it's not safe.
Are you sure?
In Canada, the rules read as if fully automatic flight is not allowed. In fact, it also states that the required system response from a loss of control signal is for the system automatically end the flight. However, I talked to the lead UAV regulations guy at Transport Canada, who stated that the rules were written in 2008. This was before automated flying was common. He stated that at this point, fully automated flying is completely legal, so long as the pilot always has the
option to take control. So for example, if you want to do mapping, you set up your lawn mower pattern and hit go. However, you always have the option to take back control.
Aren't you at the OBC right now? Isn't that automated flying? I think it's actually also beyond LOS?
I've been watching the spline feature with interest. I have to admit that I don't really get it as every pro video I've seen is much smoother. I thought spline was more about smoothing between waypoints rather than smoothing turns per say.
The intention is smoothing the whole flight. The turns all blend. With spline, there are no straight lines. Now, there might be room for improvement, this is the first release of this feature. Heck, it's not actually even released yet. But the concept is here. It no longer flies straight lines, bouncing off waypoints like a game of Pong in the sky.
Also, as to smoothness... remember, this is not a shot from a large Octocopter with a Zenmuse gimbal. That was a Tarot 650 frame. AUW of about 2kg, but with 15" props, flies for 25 minutes. And as you can see in the trees, pretty breezy. I was actually pretty happy with the stability. That was also an action cam, on a 2-axis home-made gimbal with Alexmos. It's not even completely balanced yet.
So how much of the lack of smoothness was due to physics instead of programming? This is a test quad, not a professional video machine.
But as I stated, the yawing definitely needs work.
