gtranquilla
RadioActive
But how easy is this to do since the firmware in the attached components also have to be rolled back?
Firmware summary:
A2 Firmware version: 2.1 Feature enhancements:
Enhanced performance of A2 flight control system in data loss situations that are caused by abnormal communications.
Optimized control performance, if the command of Yaw control stick is zero, the command variation of Elevator, Roll and Throttle will not change the aircraft attitude around Yaw.
Optimized IOC function and POI algorithm to improve user experience.
Optimized communication protocol.
Support to upgrade A2 GPS Module.
Fixed the attitude jitters during Fail-safe and Go Home.
A2 Firmware version 2.2 Feature enhancements:
Propulsion allocation optimization and flight stability enhancements.
New compass algorithm further reduces the impact of strong magnetic interference.
Fixed gimbal servo travel limit.
Non-advertised feature: airport proximity flight restriction.
Limitations: Loss of MR control and/or crashes as a result of airport feature and/or other issues
A2 Firmware version 2.3 Feature enhancements:
de-activates airport proximity flight restrictions
Limitations: Suspected loss of MR control resulting in crashes possibly due to GPS communication issues on CanBus port and/or shorting/heat issue.
Firmware summary:
