<!--[if gte mso 9]><xml>  <o:OfficeDocumentSettings>   <o:TargetScreenSize>800x600</o:TargetScreenSize>  </o:OfficeDocumentSettings> </xml><![endif]-->  [FONT="]The following were my comments/thoughts to the FAA regarding their so-called "interpertation"!
The FAA should separate UAS operations into three separate but distinct regulatory categories:
1) The first category, which requires the least amount of regulation, would include hobby or modeler, commercial and public safety UAS operations below 400 ft. AGL, under 55 pounds, outside of controlled airspace (Class E and G) and special use airspace (unless permission is granted from the controlling air traffic facility), and within positive sight of the operator at ALL times. [/FONT]
  [FONT="]
2) The second category would include hobby, commercial, and public safety UAS's that possess the capability to fly autonomously using autopilot systems that utilize pre-programmed GPS coordinates and are capable of flying out-of-sight of the operator. Flights would be limited to a height of 400 ft. AGL, outside of controlled or special use airspace (unless permission is granted from the controlling air traffic facility), and within a distance radius that would allow the unit to return to the take-off point without exhausting available fuel or battery power. When the unit is out-of-sight of the operator, a reliable First Pilot View system that displays flight path information and allows the pilot to maintain visual contact with the ground and airspace in its flight path would be required for safety.
3) Totally autonomous UAS's that will operate in the National Airspace System (i.e.: in navigable airspace above 400 ft. AGL, and in controlled or special use airspace). Autonomous operations in the NAS would no doubt require the operator to have stringent license requirements and extensive aviation knowledge, stringent equipment certification processes, redundant autonomous control and return to land systems, and proven collision avoidance technologies [/FONT]
  [FONT="] [/FONT]
  [FONT="]400 ft. AGL is an important distinction in this discussion, because this is truly where “navigable airspace” or the National Airspace System (NAS) begins. The Supreme Court has ruled time and again in trespass and 4th Amendment search and seizure cases that airspace below 400 ft. AGL is not "navigable airspace." The reason courts have ruled this airspace below 400 ft. AGL as non-navigable airspace is because manned flights at such a low altitude are generally considered rare and unsafe except in the vicinity of an airport. Also, the Supreme Court in Florida v. Riley used 400 ft. AGL as a guide in most part out of reasonableness and because of safety; this figure being the upper curve of most helicopter flight velocity engine out diagrams. [/FONT]
  [FONT="] [/FONT]
  [FONT="]Although courts formulated the 400 ft. AGL rule to define the limits of privacy, the FAA was not created to protect the privacy rights of citizens. So technically, the only argument the FAA can use to regulate this airspace is for the safety of citizens on the ground (14 C.F.R. @ 91.13 through 15), or for collision avoidance for aircraft landing or departing airports or operating in controlled and special use airspace (14 C.F.R. @ 91.126 through 135). I agree with and fully understand the need for the FAA to regulate or prevent UAS operations in these types of controlled airspace. [/FONT]
  [FONT="] [/FONT]
  [FONT="]The only guidance to modelers on this matter was outlined in 1981 in AC 91-57. This AC allows hobbyists to fly RC aircraft below 400 ft. (where nearly all manned flights should not occur except for takeoff or landing) over unpopulated areas and not within the immediate vicinity of an airport. The above referenced document was only an “Advisory Circular” and was not regulatory in nature. Apparently it worked fine for years, because Congress, in Public Law 112, again sets the bar for permissible hobby and modeler operations up to 400 ft. AGL.[/FONT]
  [FONT="] [/FONT]
  [FONT="]Manned aircraft and unmanned hobby RC operations generally don’t interfere with each other. I am a 12,000 helicopter pilot with 34-years of experience (24-years as a police helicopter pilot and 21-years as a military helicopter pilot) and have never had an incident with an RC flyer. And, as a RC hexacopter operator myself, I am always cognizant of manned aircraft operating in my chosen flight areas.[/FONT]
  [FONT="] [/FONT]
  [FONT="]If a 13-year old can fly a RC hexacopter in his backyard or a public park without any license or regulatory requirements, it is unreasonable to ask a real estate agent who wants to get a video of a client’s house to put on the internet to get a COA or SAC for his hexacopter. There is really no difference as long as he can do it safely. Let the local police or fire department fly a quadcopter with a FLIR for a perp search or over a fire to look for hot spots without a COA if it can be done safely. Let the commercial film crew get video of the latest model car driving across a bridge without obtaining a COA and equipment SAC if it can be done safely and within line-of-sight of the operator.[/FONT]
  [FONT="] [/FONT]
  [FONT="]The FAA does not have the manpower or financial resources to adequately regulate this explosive small UAS industry, nor should it be given additional funds or personnel to do so. The responsibility for the safe operations of these devices has, and will, continue to be dictated by the insurance industry and civil tort law. A strong body of civil case law has already been formulated in this area driven by 91-years of relatively safe “model aircraft” operations. And what one person may consider an unsafe operation might not be considered unsafe by another. Most UAS's in circulation today are relatively small, weigh less than five pounds, contain autopilot systems that include ring laser gyros and GPS for stability, and miniature microwave transmitters and receivers for First Pilot View (FPV). These systems have added an element of safety and stability to these devices that is unprecedented. And surprisingly, it makes them relatively safe to operate in proximity to people and objects.[/FONT]
  [FONT="] [/FONT]
  [FONT="]The FAA should adopt the three separate categories of UAS operations I have outlined above. It would simplify the rules for all small UAS operators (modeler, commercial, and public safety alike) and free up resources and money within the FAA to tackle the extensive and complicated job of integrating autonomous UAS's safely into the NAS.
 [/FONT]<!--[if gte mso 9]><xml>  <w:WordDocument>   <w:View>Normal</w:View>   <w:Zoom>0</w:Zoom>   <w:TrackMoves/>   <w:TrackFormatting/>   <w
unctuationKerning/>   <w:ValidateAgainstSchemas/>   <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>   <w:IgnoreMixedContent>false</w:IgnoreMixedContent>   <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>   <w
oNotPromoteQF/>   <w:LidThemeOther>EN-US</w:LidThemeOther>   <w:LidThemeAsian>X-NONE</w:LidThemeAsian>   <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>   <w:Compatibility>    <w:BreakWrappedTables/>    <w:SnapToGridInCell/>    <w:WrapTextWithPunct/>    <w:UseAsianBreakRules/>    <w
ontGrowAutofit/>    <w:SplitPgBreakAndParaMark/>    <w:EnableOpenTypeKerning/>    <w
ontFlipMirrorIndents/>    <w:OverrideTableStyleHps/>   </w:Compatibility>   <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>   <m:mathPr>    <m:mathFont m:val="Cambria Math"/>    <m:brkBin m:val="before"/>    <m:brkBinSub m:val="--"/>    <m:smallFrac m:val="off"/>    <m:dispDef/>    <m:lMargin m:val="0"/>    <m:rMargin m:val="0"/>    <m:defJc m:val="centerGroup"/>    <m:wrapIndent m:val="1440"/>    <m:intLim m:val="subSup"/>    <m:naryLim m:val="undOvr"/>   </m:mathPr></w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml>  <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"   DefSemiHidden="true" DefQFormat="false" DefPriority="99"   LatentStyleCount="267">   <w:LsdException Locked="false" Priority="0" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Normal"/>   <w:LsdException Locked="false" Priority="9" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="heading 1"/>   <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/>   <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/>   <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/>   <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/>   <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/>   <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/>   <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/>   <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/>   <w:LsdException Locked="false" Priority="39" Name="toc 1"/>   <w:LsdException Locked="false" Priority="39" Name="toc 2"/>   <w:LsdException Locked="false" Priority="39" Name="toc 3"/>   <w:LsdException Locked="false" Priority="39" Name="toc 4"/>   <w:LsdException Locked="false" Priority="39" Name="toc 5"/>   <w:LsdException Locked="false" Priority="39" Name="toc 6"/>   <w:LsdException Locked="false" Priority="39" Name="toc 7"/>   <w:LsdException Locked="false" Priority="39" Name="toc 8"/>   <w:LsdException Locked="false" Priority="39" Name="toc 9"/>   <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/>   <w:LsdException Locked="false" Priority="10" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Title"/>   <w:LsdException Locked="false" Priority="0" Name="Default Paragraph Font"/>   <w:LsdException Locked="false" Priority="11" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/>   <w:LsdException Locked="false" Priority="22" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Strong"/>   <w:LsdException Locked="false" Priority="20" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/>   <w:LsdException Locked="false" Priority="59" SemiHidden="false"    UnhideWhenUsed="false" Name="Table Grid"/>   <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/>   <w:LsdException Locked="false" Priority="1" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/>   <w:LsdException Locked="false" Priority="60" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Shading"/>   <w:LsdException Locked="false" Priority="61" SemiHidden="false"    UnhideWhenUsed="false" Name="Light List"/>   <w:LsdException Locked="false" Priority="62" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Grid"/>   <w:LsdException Locked="false" Priority="63" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 1"/>   <w:LsdException Locked="false" Priority="64" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 2"/>   <w:LsdException Locked="false" Priority="65" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 1"/>   <w:LsdException Locked="false" Priority="66" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 2"/>   <w:LsdException Locked="false" Priority="67" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 1"/>   <w:LsdException Locked="false" Priority="68" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 2"/>   <w:LsdException Locked="false" Priority="69" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 3"/>   <w:LsdException Locked="false" Priority="70" SemiHidden="false"    UnhideWhenUsed="false" Name="Dark List"/>   <w:LsdException Locked="false" Priority="71" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Shading"/>   <w:LsdException Locked="false" Priority="72" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful List"/>   <w:LsdException Locked="false" Priority="73" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Grid"/>   <w:LsdException Locked="false" Priority="60" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Shading Accent 1"/>   <w:LsdException Locked="false" Priority="61" SemiHidden="false"    UnhideWhenUsed="false" Name="Light List Accent 1"/>   <w:LsdException Locked="false" Priority="62" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Grid Accent 1"/>   <w:LsdException Locked="false" Priority="63" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/>   <w:LsdException Locked="false" Priority="64" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/>   <w:LsdException Locked="false" Priority="65" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/>   <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/>   <w:LsdException Locked="false" Priority="34" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/>   <w:LsdException Locked="false" Priority="29" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Quote"/>   <w:LsdException Locked="false" Priority="30" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/>   <w:LsdException Locked="false" Priority="66" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/>   <w:LsdException Locked="false" Priority="67" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/>   <w:LsdException Locked="false" Priority="68" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/>   <w:LsdException Locked="false" Priority="69" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/>   <w:LsdException Locked="false" Priority="70" SemiHidden="false"    UnhideWhenUsed="false" Name="Dark List Accent 1"/>   <w:LsdException Locked="false" Priority="71" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/>   <w:LsdException Locked="false" Priority="72" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful List Accent 1"/>   <w:LsdException Locked="false" Priority="73" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/>   <w:LsdException Locked="false" Priority="60" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Shading Accent 2"/>   <w:LsdException Locked="false" Priority="61" SemiHidden="false"    UnhideWhenUsed="false" Name="Light List Accent 2"/>   <w:LsdException Locked="false" Priority="62" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Grid Accent 2"/>   <w:LsdException Locked="false" Priority="63" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/>   <w:LsdException Locked="false" Priority="64" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/>   <w:LsdException Locked="false" Priority="65" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/>   <w:LsdException Locked="false" Priority="66" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/>   <w:LsdException Locked="false" Priority="67" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/>   <w:LsdException Locked="false" Priority="68" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/>   <w:LsdException Locked="false" Priority="69" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/>   <w:LsdException Locked="false" Priority="70" SemiHidden="false"    UnhideWhenUsed="false" Name="Dark List Accent 2"/>   <w:LsdException Locked="false" Priority="71" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/>   <w:LsdException Locked="false" Priority="72" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful List Accent 2"/>   <w:LsdException Locked="false" Priority="73" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/>   <w:LsdException Locked="false" Priority="60" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Shading Accent 3"/>   <w:LsdException Locked="false" Priority="61" SemiHidden="false"    UnhideWhenUsed="false" Name="Light List Accent 3"/>   <w:LsdException Locked="false" Priority="62" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Grid Accent 3"/>   <w:LsdException Locked="false" Priority="63" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/>   <w:LsdException Locked="false" Priority="64" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/>   <w:LsdException Locked="false" Priority="65" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/>   <w:LsdException Locked="false" Priority="66" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/>   <w:LsdException Locked="false" Priority="67" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/>   <w:LsdException Locked="false" Priority="68" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/>   <w:LsdException Locked="false" Priority="69" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/>   <w:LsdException Locked="false" Priority="70" SemiHidden="false"    UnhideWhenUsed="false" Name="Dark List Accent 3"/>   <w:LsdException Locked="false" Priority="71" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/>   <w:LsdException Locked="false" Priority="72" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful List Accent 3"/>   <w:LsdException Locked="false" Priority="73" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/>   <w:LsdException Locked="false" Priority="60" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Shading Accent 4"/>   <w:LsdException Locked="false" Priority="61" SemiHidden="false"    UnhideWhenUsed="false" Name="Light List Accent 4"/>   <w:LsdException Locked="false" Priority="62" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Grid Accent 4"/>   <w:LsdException Locked="false" Priority="63" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/>   <w:LsdException Locked="false" Priority="64" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/>   <w:LsdException Locked="false" Priority="65" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/>   <w:LsdException Locked="false" Priority="66" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/>   <w:LsdException Locked="false" Priority="67" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/>   <w:LsdException Locked="false" Priority="68" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/>   <w:LsdException Locked="false" Priority="69" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/>   <w:LsdException Locked="false" Priority="70" SemiHidden="false"    UnhideWhenUsed="false" Name="Dark List Accent 4"/>   <w:LsdException Locked="false" Priority="71" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/>   <w:LsdException Locked="false" Priority="72" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful List Accent 4"/>   <w:LsdException Locked="false" Priority="73" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/>   <w:LsdException Locked="false" Priority="60" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Shading Accent 5"/>   <w:LsdException Locked="false" Priority="61" SemiHidden="false"    UnhideWhenUsed="false" Name="Light List Accent 5"/>   <w:LsdException Locked="false" Priority="62" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Grid Accent 5"/>   <w:LsdException Locked="false" Priority="63" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/>   <w:LsdException Locked="false" Priority="64" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/>   <w:LsdException Locked="false" Priority="65" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/>   <w:LsdException Locked="false" Priority="66" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/>   <w:LsdException Locked="false" Priority="67" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/>   <w:LsdException Locked="false" Priority="68" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/>   <w:LsdException Locked="false" Priority="69" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/>   <w:LsdException Locked="false" Priority="70" SemiHidden="false"    UnhideWhenUsed="false" Name="Dark List Accent 5"/>   <w:LsdException Locked="false" Priority="71" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/>   <w:LsdException Locked="false" Priority="72" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful List Accent 5"/>   <w:LsdException Locked="false" Priority="73" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/>   <w:LsdException Locked="false" Priority="60" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Shading Accent 6"/>   <w:LsdException Locked="false" Priority="61" SemiHidden="false"    UnhideWhenUsed="false" Name="Light List Accent 6"/>   <w:LsdException Locked="false" Priority="62" SemiHidden="false"    UnhideWhenUsed="false" Name="Light Grid Accent 6"/>   <w:LsdException Locked="false" Priority="63" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/>   <w:LsdException Locked="false" Priority="64" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/>   <w:LsdException Locked="false" Priority="65" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/>   <w:LsdException Locked="false" Priority="66" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/>   <w:LsdException Locked="false" Priority="67" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/>   <w:LsdException Locked="false" Priority="68" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/>   <w:LsdException Locked="false" Priority="69" SemiHidden="false"    UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/>   <w:LsdException Locked="false" Priority="70" SemiHidden="false"    UnhideWhenUsed="false" Name="Dark List Accent 6"/>   <w:LsdException Locked="false" Priority="71" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/>   <w:LsdException Locked="false" Priority="72" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful List Accent 6"/>   <w:LsdException Locked="false" Priority="73" SemiHidden="false"    UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/>   <w:LsdException Locked="false" Priority="19" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/>   <w:LsdException Locked="false" Priority="21" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/>   <w:LsdException Locked="false" Priority="31" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/>   <w:LsdException Locked="false" Priority="32" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/>   <w:LsdException Locked="false" Priority="33" SemiHidden="false"    UnhideWhenUsed="false" QFormat="true" Name="Book Title"/>   <w:LsdException Locked="false" Priority="37" Name="Bibliography"/>   <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/>  </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style>  /* Style Definitions */  table.MsoNormalTable 	{mso-style-name:"Table Normal"; 	mso-tstyle-rowband-size:0; 	mso-tstyle-colband-size:0; 	mso-style-noshow:yes; 	mso-style-priority:99; 	mso-style-parent:""; 	mso-padding-alt:0in 5.4pt 0in 5.4pt; 	mso-para-margin:0in; 	mso-para-margin-bottom:.0001pt; 	mso-pagination:widow-orphan; 	font-size:10.0pt; 	font-family:"Times New Roman","serif";} </style> <![endif]-->
