Motopreserve
got a used tarot T-2D, it arrived w/ 1.3 firmware - somewhat working but with some jerking if it rolled to the right when testing on bench.
I updated it to 1.5 (controller & motor) and the thing freaked out. It started jerking more violently and faces only straight down. The 3D depiction is nowhere near correct.
I put it back to 1.3, and somewhere in there it began losing power intermittently. I found some stray strands loose on the solder points on the gyro. So I fixed that - no more loss of power, but same jerking.
It shows up in GUI. Seems to update (controller is fine, but motor update never shows version # although it says it completes successfully).
Any thoughts? Fried gyro?
I have been powering with a fully charged 3S 450mah battery.
Thanks in advance.
