I've been using three very unique 15x5 prop designs on my new hex.  Each has their benefits and disadvantages.  They are the new APC multirotor, the new T-Motor carbon fiber with the flared tip and a set of narrow graupner e-prop style props. I've found.... the APC have more mass and would not allow the motors to respond as fast as the flight controller required resulting in less stable flights, especially in windy conditions; they do not break (as easy) when contacting the ground.  The new T-motor style are very nice, less mass, quicker response, quieter, I like the flat hub mount, and gave the best flight time; because of the flat hub mount they only fit motors designed with this style.  The graupner style props flew best in the wind, and fit most motor mounting hubs with a single spindle; they has a little less flight time.   I fly with a single 10,900 mah 4s battery.  My guess is that the APC props would work fine with a 6S battery as there would be more voltage to control the motors with absolute response.
-Bob
