I've just had an f550 built up for me, and set up with a BT, mini iOSD, GoPro Zenmuse gimbal, Fatshark 5.8ghz FPV system, aeroxcraft landing gear, etc...
In addition to flying this machine for fun, I also intend for it to do a little work on occasion.
I live in the middle of the Canadian prairies...LOTS of agriculture all around. I've had a bunch of farmers express interest in seeing what this Hex will do in terms of
field mapping; evaluating visible moisture levels prior to seeding, growth patterns, evaluating the need for herbicides, evaluating damage to crops from weather (excessive rain, hail or wind)...basically everything you can evaluate and/or quantify with conventional photos. I am also looking at the possibility of adding an IR sensor to the mix, for looking at fungal infections in grain crops, etc.
Obviously, I can fly these sorts of flights either LOS or FPV, but if the ground station is accurate enough, that would certainly add to the whole equation.
For those of you with experience in using the ground station for flight planning; what has your experiences been like? Is it an accurate enough process that I could rely on these "missions" to be accurate within 50-75 feet? Have you had any "why the *(^( did it do that??" moments with it?
Any and all input would be greatly appreciated!
