ZAxis
Dave ...
From my reading of the A2 manual it seems as if you will never get more than the eight channels required by the A2 for sticks, gps select, gimbal control if you use the DSM2 satellites. So if you want LANC, LED on/off, shutter control, etc you're b*****red unless you can use disconnected but bound satellites and normal Spektrum Rx together with channels mapped between them. Not sure how to do this or if its possible.
The DJI S-bus adaptor will at least give you the opportunity to assign 8 channels of your Spektrum Rx to the A2 leaving you all the other channels to do what you want to. .... but its not available right now so I'd suggested the Futaba SBE-1 adaptor that do the same job as it is available immediately. Its does not require any other Futaba gear, its just a module that will sit between the Spektrum Rx and the A2. This way you can keep using the DX18. Seems like it was introduced to allow any Rx to talk to Futaba's well respected heli gyro. I'd talk to some Futaba shop to confirm this if you want to go that way.
andy
andy
Andy I DONT WANT TO USE FUTABA! the quality of TX is absolutely pants compered with the DX18.
IF THEY - DJI had built in telemetry then I may have been tempted but they didn't.. Just a total wist of space and resources to build in a futaba RX in the 'MOST ADVANCED' flight controller!
