jfro
Aerial Fun
Going to be setting up x8 tomorrow with Naza-M v2, first time Naza user.
Using with Turnigy 40amp plush.
Do some research tonight so I though I'd start a thread that I could use to ask questions as I tackle a new flight controller.
1st up........
From Naza manual " If you use 3rd party ESCs, make sure the ESCs travel
midpoint is at 1520us. DO NOT use 700us travel midpoint ESC, as it
may lead aircraft to fly away or cause injury and damage. After ESCs
connection , calibrate ESCs one by one through the receiver directly
before connect them to your MC, Make sure program all of them into
Governor off, Break off and Normal Start up to get best experience."
My current settings are :
Brake off
Battery Type NiMh/Nicd
Cutoff Mode Cut Off
Cutoff Threshold Low
Startup Mode Normal
Timing Medium
I assume these should work. I just don't know what the travel mid point of the 40amp plushes are, how to check them, or change them if possible. Any suggestions. Will be running 8 Avroto 2814-11's. on 4s 40c batteries.
1st up........
Brake off
Cutoff Mode Cut Off
Startup Mode Normal
Timing Medium
