DJI has released the Naza-M firmware 3.16, the BTU and the iOSD mini
BTU Module
The Naza-M now provides assistant software for iPhone4s, iPhone5, iPad3, iPad4, iPadmini, iPod5. You can do parameter adjustments at any time on your mobile devices, using only the BTU with a built-in Bluetooth module which makes it easier and convenient. It uses low power Bluetooth to minimize the power consumption of your mobile devices. It is easy to use and will automatically save your last connection records. The password mechanism ensures your safety link. Parameters can be automatically synchronized to the Cloud Server and can be restored immediately when you changed your mobile devices.
Built-in Bluetooth(4.0)
Working Temperature: -10℃~+50℃
Communication Distance: 50m
Weight: 17g
Power Consumption: 240mw(0.04A@6V)
iOSD mini
The Naza-M now supports iOSD Mini. This will undoubtedly give you a fantastic FPV flight performance. Depending upon DJI’s accumulation of historic and reliable information integration technology, the iOSD Mini can grab the most accurate first-hand flight data information in the shortest possible time.
Voltage: 6V
Working Temperature: -20℃~+60℃
Video Input/Output Mode: PAL/NTSC(automatically recognize)
Weight: 14g
Working Current (Typical Value): 180mA@6V
The new firmware supports Bluetooth adjustment.
Tips before upgrade:
1, Since v3.16 upgrade will reset all parameters, Make sure to reconfigure all parameters in the assistant software after upgrading firmware, re-calibration your receiver;
2, For PHANTOM customers, before upgrade, please notice the receiver type at [Basic -> RC] in assistant software. After upgrade you could download the PHANTOM default configuration file from dji website, import to MC and choose right RC type, then re-calibrate your receiver; PHANTOM default configuration file download link:
http://www.dji-innovations.com/download/phantom-downloads/
2, It is required to “Restore default settings” in “Tool” page if the firmware is degraded to below v3.16, otherwise the flight performance will be affected.
What’s new?
Firmware
Parameter configuration by NM Assistant is supported. (BTU module is required. Download the App software from iOS App store or scan the QR code to get the download link.)
iOSD mini supported.
S-bus II receiver supported.
Optimize the warming up condition, to avoid a long wait period before aircraft can takeoff.
Software
Add tips for IMU Advanced calibration time out.
Manual
Add connection diagrams when used with other DJI products.
Notices:
Make sure to reconfigure all parameters in the assistant software after upgrading firmware, since V3.16 upgrade will reset all parameters.
For safety reason, do not use power battery during firmware upgrade.
photobobga
Very excited about having these new features, thank you! On a personal note having the ability to use an android device would be very much appreciated.
