Hey folks,
Have a skyjib heavy coaxial for a while now and I love it. Have been flying 1d and 5d on it with good results. They were mainly test cameras though and I have now switched to the proper working camera (F5 with Cooke prime) and the payload went up to 6.5 kg, 14kg total flying weight and now a few small issues I had before became more serious.
Here are the problems I'm having: when flying DSLRs the top motors were getting pretty warm while the bottom ones were completely cool but because the payload was much lighter it didn't really manifest in flight characteristics.
Now however with the heavier payload the top motors are getting REALLY hot. Around 80-90 degrees. Almost too hot to touch while the bottom ones are around 20 degrees. As a result the copter can yaw randomly when hovering and loose altitude. When I yaw in one direction it stops perfectly when I release the sticks but when I do the same in the opposite direction it drifts a bit before stopping.
I was in touch with Matjaz from kopterworx and he recons that some of the motors aren't aligned/leveled perfectly so the top ones are constantly working to stop the heli yawing hens the overheating.
I aligned the top and bottom props on each arm perfectly parallel to each other with an electronic caliper, but my question is how to get each arm perfectly level. Matjez was saying that even 1 degree can cause problems but can't think of a way to level the arms to that accuracy.....does anybody have a good method to do this? Also any other ideas of why I'm having these issues?
Any help would be much appreciated!
