Since most of the Quads weighs in a range of 1.2-1.5 kgs. So i would like to know that what are the appropriate motors available to lift that much of weight.
work out what your required watts are, 1.5 kg will need 200 to 250 watts to hover, or 62 watts per motor, so you really want a motor that can handle 2-3 times that (120-180 watts)
Your next choice is kv, but thats not straight cut - two 900 kv motors on paper will respond diferently, depends on magnet count, winding size, stator diameter.........
but pretty much aim for 700 to 1000 kv, and adjust prop size to get the desired thrust
Would you recommend the RC Cams as a direct replacement for my RC Timer 750kv's that I'm running on my tricopter? I'm using the 25-30 HK SS ESC's. I feel a little underpowered at times and don't think these things things match up to well to each other, depending on when you bought them. The same motors from different orders will perform much differently and I would like to avoid that with my next motor set.
