Hi all
Just received some new batteries, Turnigy 6s 5000mAh
The cables on them are HUGE (probably about 7mm)
I cant see how I am going to get my XT60 connectors soldered onto them!
Any ideas?
D
| AWG | Diameter | Turns of wire (no insulation) | Area | ||||||||||
| (inch) | (inch) | (mm) | (per inch) | (per cm) | (kcmil) | (mm2) | |||||||
| 0000 (4/0) | 0.4600* | 11.684* | 2.17 | 0.856 | 212 | 107 | |||||||
| 000 (3/0) | 0.4096 | 10.405 | 2.44 | 0.961 | 168 | 85.0 | |||||||
| 00 (2/0) | 0.3648 | 9.266 | 2.74 | 1.08 | 133 | 67.4 | |||||||
| 0 (1/0) | 0.3249 | 8.251 | 3.08 | 1.21 | 106 | 53.5 | |||||||
| 1 | 0.2893 | 7.348 | 3.46 | 1.36 | 83.7 | 42.4 | |||||||
| 2 | 0.2576 | 6.544 | 3.88 | 1.53 | 66.4 | 33.6 | |||||||
| 3 | 0.2294 | 5.827 | 4.36 | 1.72 | 52.6 | 26.7 |
Had same issues before. I really heat up the wire and apply solder making sure it penetrates and covers all around. Then I use a Dremel with sanding drum and reduce the wire diameter down to fit the connector. Not the coolest thing I have done as it effectively reduces the carrying capacity of the wire (8awg becomes 10 etc).
But when you look at the overall scheme of things, isn;t the battery wire and battery first connector really the bottlenek of the whole system? For example, an XT90 is rated at about 90amps. Divide that by 8 motors on an Octo and looks to me like each motor can only draw max 11.25amps (all motors at same time) or the connector could fail. Of course all of this is theory and reality is another thing. It's a multirotor mystery.
