With the S800 prop length limited to a maximum of 15" about the only thing one can change is pitch. Or is it .... ?
I asked APC. This is their response.
"At higher altitudes you will need more blade area to offset the effects of the thinner air. Higher pitch will also help but your battery life will go down. I would suggest the 13x4.7SF and the 16x4E (we just came out with this size, it will be on our website next month). Some folks use our 15x10E and EP on quad-copters, you can try this setup at higher altitude as well.
I don't know of a pitch vs. altitude chart. It should really be a diameter (or blade area) vs. altitude chart.
You are welcome to study our performance data:
http://www.apcprop.com/v/downloads/PERFILES_WEB/datalist.asp
The coefficients are dimensionless, just plug in the air density to get the relative thrust increase/decrease.
BTW, if you're interested in trying the 16x4E and EP ASAP, let me know."
It doesn't really help with the S800 - except for the 15x10 suggestion perhaps. But then again, that does not really mesh with what he was saying about blade
area being more relevant than
pitch.
So we are still in Guessitland. Interesting info on the APC site about maximum prop rpm's. The SF props have a surprisingly slow maximum. Way under what we run them at !
I have a suspicion that the Wookong senses performance (or altitude) and adjusts things so that the Tx stick is always around centre for hover.
