MultiWii Flight Board
Crash
Defies Psychics
I finally got around to wiring up the MultiWii board that I put together months ago.
The wiring is a bit of a mess because I didn't have an interface board and with it just being a test craft, I did it fast. Bottom line is that it flew well with no tuning. I only flew half a battery but so far I like the board.
I used the old way of doing things because that's the way it was done 5 months ago when I started collecting pieces. It's an Arduino Mini Pro ($20), USB adapter board ($10 or $20), a gutted Wii remote, and a gutted Wii Nunchuck. Everything is shoe gooed together on the back of an old credit card.
I used my Jakub frame that previously held the KapteinKuk board. One of the things I like is the ability to switch to stable mode which uses the Accelerometer to self level.
More Info on the MultiWii setup can be found here:
http://www.rcgroups.com/forums/showthread.php?t=1340771
Crash -
I'm glad to hear that it flew well "out of the box"! I just put one together today using the Paris 3.0 board, and I have loaded MultiWii 1.7 on there. Everything shows up correctly (I think) in the GUI, and I'm here taking a break before I choose motors and ESC's. I'm notgoing to order new ones - I'm stripping some of my other birds that have not turned out so well.
I'm thinking of using the Exceed RC 30A ESC's from my Mini-KK Hexa (I broke one of the birch-wood arms, anyway), along with EITHER some extra Robbe 2827's (extras for my stock MK Hexa) or some extra Turnigy 2217/20's that I have laying around.
I'll post video if I get it flying!
Buzzed
Hey Crash glad you got your new bird up and flying. Does the board do a pretty decent job of self leveling?
Oh and could you possibly fly it over this way so I can use that MasterCard? I Need to buy more parts for my projects and your card will work just fine. View attachment 306
Crash
Defies Psychics
Oh and could you possibly fly it over this way so I can use that MasterCard? I Need to buy more parts for my projects and your card will work just fine. View attachment 534
It levels well. I can snap the sticks and the quad will hit about a 45 degree angle and bounce back immediately. I do need to use a lot of trim to maintain a level hover. It's a problem with my setup that I haven't figured out yet. I ordered a new board that has all the sensors built-in so I'm not going to worry about it too much.
All in all, it's a good setup for a beater or sport quad or for someone who wants to start cheap. The MK battery costs more than this thing. ;)
BTW, I erased the mag strip on the mastercard and cut the numbers out. ;)
Buzzed
Does that cost include the frame too???
I just knew you disabled the card Crash, I was just messin w/you a bit.
Crash
Defies Psychics
It's on a Jakub frame that costs $70 I think. You could build this on an old yard stick and plastic tub from the dollar store. So including a 3000mAh battery it was a little more than $200. Motors and ESCs were about $10 each.
The new Quadrino board I bought is from here: http://www.rcgroups.com/forums/showthread.php?t=1261382&page=814&highlight=nospam2#post17838612
http://www.declspec.com/quadrino-datasheet.pdf
That was another $150 but it will clean up the wiring and have more and better sensors. (That board is brand new BTW - I hope it works as it should)
That Quadrino Board looks really nice! It seems to address most of the common issues I have been reading about.
That is, I like the fact that the Quadrino has a built-in 5v voltage reglator, so you can just plug your battery directly into it. (I've read posts where folks have problems because they are using the 5v from multiple ESC's BECs.)
I also like the built-in FTDI -- just connect with a mini-usb cord! Very nice.
I like the fact that it has the built-in ITG3200 and BMA180 -- better quality than the WMP and NK gyros and accellerometers. I like the easy addition of battery voltage monitoring and low battery warning . . . dang - I want one!
You say $150. Did you add the Magnometer and the Baro? Does the MultiWii code support these features yet?
Last question: What is the story on GPS hold for Multi-Wii?
Crash
Defies Psychics
Yes, I got the baro and magnetometer. The baro support is crude at the moment. I recall there being an accuracy of a couple meters but someone recently posted code that brought that down to 20cm. There is support for the magnetometer in the code. I have no idea how well it works.
From what I understand, GPS hold would need another processor. I wouldn't hold your breath on that one. Openpilot or Arducopter will probably get there first. I could be wrong though - stuff changes fast.
I bought one of these just in case: http://www.dealextreme.com/p/em-411-gps-engine-board-module-with-sirf-star-iii-chipset-80037
