I too have both these controllers and the default config is the standard counter rotating props. I've managed to create a custom motor mixer on my WKM to achieve same rotation prop configuration on the same arm for my X8. The reason I wanted this is to be able to use vectored thrust from slightly rotated arms to achieve yaw rather than RPM/torque changes only. Using vectored thrust(for example on my quad setups) achieves super smooth yaw(pan) and less attitude variations when doing so. The other problem I was having with my WKM X8 setup, which I guess is appliable to hot environments like the one I work in(45 degrees celcuis), is that due to the inherent loss of efficiency in coaxial setup, the bottom motors always accumulate more heat because they are trying to maitain yaw authority while also compensating for the thrust loss due to the fact that they are running in the prop wash of the top motors. The result of this overheating is very interesting: as their temperature increases, the apparent strenght of their magnets decreases very slightly(temperature difference between top and bottom motors upon landing is 10-15 degrees celcuis) causing them to drop their RPM very slightly and inadvedently causing a slow yaw in the direction opposite to their direction of rotation. In other words, because they work so hard and slightly overheat, they end up providing less thrust(and torque) and lose their ability to counter act the yaw torque generated by the top motors. My conclusion that this is infact what's happening came from numerous experiments where my WKM X8 would start out fine and after 5-6minutes of flight(after the motors get nice and hot) it would start yawing on its own(more so if I'm carying my camera/gimbal load)....landing for a couple of minutes resets this behavior. I never noticed this behavior in the winter. Without any modifications except for the prop redistribution, motor direction modification, applying the custom motor mixer solved this problem immediatly...plus it gave me the added advantage of being able to tilt my motor arms 3-4 degrees to use thrust rather than torque only to create the yaw forces. On the WKM, I could probably increase the yaw gain but I guess that would just wastes valvuable energy. Anyway the overall effect on my specific X8 with the custom motor mixer is better yaw authority, less attitude impact from yaw, and less thermal stress on the bottom motors. This is all good, but I wonder why no one else has this same setup, it is very likely that my logic is flawed in one way or another
If you have round arms on your X8(Y6 would be a bit more tricky to setup vectored thrust) and you're interested in testing this out, I can pass on my custom motor mixer. If it works for you, it may significantly improve the pan movements on your X8 especially if you have a fixed camera gimbal(i.e. gimbal with no independant 360 deg rotation).
Very interested to hear your thoughts on this.
Thanks!
