CLUELESS QUAD BUILDER
SANDS
Hello everyone,
I am new to building quads... Hopefully I can get a better understanding of the do's and don'ts when creating my machines.... With that being said, here us my dilemma.. I have a SPF3 FC and a
FRSKY D8R-II receiver... Can someone/anyone explain to me how I am suppose to hook the receiver up to my FC and give me some good places to look for info
Thanks in advance for the advice and tips.
DroneTalk
R/C Expert
Staff member
The connections on top is I02 for sbus ibus The bottom is I01 pwm& ppm.
If you Google spf3 pdf file it will show what every single thing is for.
I use ppm which is 3 wires 5v ground, signal.
Trevcharl
Yes it is better to use the serial output as mentioned above, I do have a suspicion that you might have to download Cleanflight or Betaflight, so you can assign the channels 5 to 8, that is if you had to buy a separate controller. The assigned functions on the controller have to match that of the Flight controller. If your system came with a controller, dont worry about this, they would have done this already.
