yet more dji niggles
plingboot
had chance to fly a few packs with both the wkm and naza today.
first tentative fpv flight with the naza was ok, but not the best location.
i do however keep experiencing niggles which spoil it all.
naza, as the flight progresses, the throttle becomes less and less responsive - still plenty of juice in the pack - but full throttle is needed just to hop around on the ground.
wkm, initially the flight was fantastic. superbe responce, flew like a dream, but then it began to flinch in the air and in gps hold it would suddenly drop to the ground before lifting off again.
i'm also noticing an intermittent double blue flash - not sure what this means.
the theme running through both quads is initially fine, then progressively poor responce and stability.
both running hw esc's
broadwing
Bleu LED?
I had that after switching off transmitter whit the returnhome test!!
Then the machine took over control..........
DennyR
That sounds like you battery levels are not set correctly or your batteries are duff. It is going into autoland mode.
