YellowJacket 5.8 Pro Diversity Receiver + 2 Patch Vitenna! and 2 standard antennas
DaveK
Items sold :)
The YellowJacket 5.8 Pro is designed to be compatible with 2.4GHz remote control transmitters and receivers that are quickly gaining in popularity. Using Iftron's exclusive technology, YellowJacket switches instantly to the best signal between video frames where it can't be seen. Nearly new only used a few times.
€295 + P&P.
Tornvig
Flybypix
Item received - Thanks.
I must do something totally wrong as I can't make it hold the the video link more than 10 meters…
I have bin trough the manual and I'm out of options. Please advise me what to do...
DaveK
Hi Bo
Make sure your are using a Iftrontech transmitter and Iftrontech PAL camera with the receiver which you can get from www.iftrontech.com also try different channels on the receiver until you get a good signal and make sure you are out in an open field away from interference when testing.
Ira Faberman from Iftrontech is good for advice regarding there products ira@iftrontech.com
Regards
David
