AirShooter
FlyCam UAV
So I've got "U" channel on 3 pos sw on my futaba 10CHG mapped to switch between GPS-ATTI-ATTI, however every time I throw the switch, the assistant says "RC lost" unless I leave it in the middle (ATTI) then it says "NORMAL" however even when it says signal lost, the transmitter is still working and the green light on the A2 receiver stays solid green, If I switch the transmitter off, it goes red like it should however I'm not seeing failsafe activate. Help!.
Here is a link to a video of what its doing when I flip it back and forth http://youtu.be/To0ZRPJWisI?list=UU_mMqCPwVhBKQEoRtFbIo3Q little background, this is all on a bench test scenario with no motors or ESC's attached, not sure if that makes a difference. It also boots up in assistant with "bad compass data" however I can take the whole mess outside and flip the U switch a million times back and forth and it will not calibrate, maybe cause it knows theres no motors or ESC's and it's like why bother dummy..?
I just wanted to do as much pre-config with tx and rx before I commit to using this system. Thanks in advance for any help or advice!
