Waterproof Quads now available
JAZCAM
Demo video for the KISCopter waterproof, amphibious quadrotor.
Just exploring production of our waterproof design developed for use in close in filming of regattas and other boating events. The design is based on the KIS principle, Keep It Simple which means:
- All our frames are based primarily on easily available parts with a minimum of custom fabricated parts. The booms are all made from easy to source aluminum or carbon helicopter tail booms.
- Our frames are primarily all aluminum with aviation grade on the high end machines. Aluminum bends and can be repair easily. Carbon, eglass, etc may be lighter and may be stronger, but these materials break which results in costly repairs.
- Nearly all of our frames are modular and disassemble and reassemble quickly and easily. Most simply snap together.
-Our frames are built to be very strong and can take some abuse. Because fo the clip together designs in a crash the frame simply comes apart thus absorbing most of the impact. One of our quads and a Hexa are used in flight controller testing and development and they have both been involved in several crashes. The Hex once fell from 50m due to a connector failure. It was flying again in an hour. Try doing that with some other frames.
- All of our frames pack for easy transport. The waterproof frames even come with a custom dry bag. Metal or Pelican style cases will are made available for all of our frames.
- Our frames are very flexible in terms of load, configuration, camera mounts, etc. The basic quad frame can be converted to a hex or back to quad in 20min or less. The Octo frame can be converted or built as a quad, XY8, Y8, X6, or X8. We will also offer our own gimbals and mounting systems for other major mounts and gimbal systems.
View attachment 4593View attachment 4594View attachment 4595
Some key features of the WetQuad are:
- The ESCs, flight controller, video tx, telemetry tx, GPS, RX are all keep in a nearly waterproof container. The only opening is a small pinhole which acts as a static port for the flight controller's altimeter in which water is prevented from entering by the higher ambient pressure inside the enclosure.
- The ESCs are mounted to the aluminum base of the enclosure with heat transfer glue or CPU grease. The enclosure base acts as a heat sink for the ESCs. Additional heat sinks can be added to the bottom of the base as required.
- The motor leads and gimbal extensions (if equipped) pass through a silicone seal in the bottom of the enclosure.
- The booms and camera mounting plate clip on. The quadrotor can be assembled or disassembled in less than a minute.
- Supports up to 28xx series motors and 13in props. In testing, we have lifted an Canon EOS 600 with 18-55 IS lens on 12in props. We do recommend flying with the cover off in this case though.
- Total weight without batteries and with jDrones large motors, 30A escs DJI Naza controller, and GoPro mount with waterproof case is 1.1 kg. No landing gear for amphibious flight.
- With the jDrones 880kv (large) motors, flight times on 3sP1 3600ma packs are 6-7 minutes. On 4sP1 5000ma packs flight times are over 12min with a gopro.
- Two types of landing gear are available as an option, camera mount mounted and folding boom attached.
Foam amphibious floats will be available. For testing 4 empty small plastic water bottles were taped to the arms for flotation.
Pricing has yet to be set. We are still working on a method of mass producing the custom parts (CNC machine coming soon!) The WetQuad will be available as a basic frame, with motors and escs, and RTF with DJI Naza, Ardupilot APM, or WKM flight controllers.
We can do one off orders now on demand. Please contact directly to inquire about pricing and configurations available.
jforkner
  • How do you keep higher pressure in the "nearly waterproof container"?
  • Wouldn't higher pressure in the container cause the barometer to misread the altitude?
  • Are the motors waterproof?
  • How is your quad amphibious (i.e., Amphibious means able to use either land or water)?
Thanks.
Jack
JAZCAM
Thanks.
Jack
Actually, the pressure is from a thermal difference due to the heat given off by the ESCs. Strange but it works. Even so, the only opening is a pin hole on the top of the case so it would have to land upside down and stay there for quite a while to get any water in the case. Even if such were to happen, just keep it inverted and remove the top. No problems. There are no other unsealed openings in the case and the lid is sealed with an o-ring and clamps. All the through bolts are o-ringed or sealed with silicone sealant.
Yes, the altitude is probably being read a bit high but it doesn't matter in flight. Altitude hold is all about differences. Even if it reads high alt hold works because it's not changing (unless climbing or descending of course. ). I haven't flown it with telemetry so I don't have accurate numbers on how the altitude reading drifts higher during flight. Should be easy to test with an APM though.
No, the motors are not waterproof nor do they need to be. The only water sensitive part on the motors is the bearings which are easy to handle by keeping them oiled or by using sealed bearings. In any case, it is recommended to hit the motors with wd40, lube-40 or similar after flying. If operating off of salt water the bearings should be sealed and the motor internals shellacked or similarly protected. On floats when alighted the booms are not in the water and the bottom of the motors is at least 5cm off the water at all times.
Yes, it can land and takeoff from water as the video shows. With landing gear, or w/o a camera mount it can land on land no problem. However, I always hand launch and catch so for us it doesn't matter. Pilot preference.
I have over 100 flights off of water and several hundred hand launched on the prototype without any problems or water damage to any components.
JAZCAM
Please do. It's quite interesting to land on the water (assuming the camera is waterproof like a GoPro).
I designed this one because we had a forced water landing on a offshore shoot last year that cost the camera (NEX-5), all the ESCs, all the batteries, and all the rear motor bearings. Quite an expensive landing. For this rig it would have been a non-event.
JAZCAM
View attachment 7756View attachment 7757View attachment 7758View attachment 7759View attachment 7760View attachment 7761View attachment 7762
The WetHex and WetHex XL waterproof multirotors are now available. These build on the design of the WetQuad but in a hexacopter format. The standard model can lift up to 1kg. The XL up to 3kg depending on motors.
We are also about to release the UniRotor convertible multirotor which can be flown as a quad or hex and can be converted between the two in minutes.
Contact via email at jazcamap@gmail.com or in our RCGroups Blog at http://www.rcgroups.com/forums/member.php?u=271088
Daniel Page
Hi , Am wondering if you still have Waterproof Multirotors available for sale? Is there a site or other contact?
thank you
Daniel
