WARNING ON 5.12a 1.30a Firmware, Software
VINHEX
After reading through the manual on the WKM yesterday as you do, double checking every thing, I realised that my GPS was set 2 cm the wrong way, not an issue with flying just thought I would correct it.
WARNING.
When I opened the settings I found that my IMU and GPS locations where all default.. Thinking I had a brain fart, I re-entered the settings. Flight was smooth.. However plugged back in after flight and they where default again!!!! So adjusted, and selected write to make sure.. Unplugged and plugged back in, DEFAULT... I'm not sure if it's my setup BUT CHECK IT GUYS...
