It used to be you'd get 5.8ghz equipment with the highest output power you could afford and that would be the end of it.  Then came FPV group flying, then racing and eight channels wasn't enough.  Too much power and you'd also be causing interference with your friends' reception.  So along came better antennae, lower power output and more channels followed by more channels!
Now, BuddyRC.com has what might be the ultimate in current tech analog video transmitters, switchable channels AND switchable power output!
I present to you, the DragonFlyer DRAK 40 channel video transmitter with switchable power output and multiple (%V and 12V) DC power outputs for whatever camera you're using!
http://www.buddyrc.com/dragon-rider-5-8g-40-channel-adjustable-fpv-av-transmitter.html
Dragon Rider Drak 5.8G Hz, 40 channel adjustable wireless AV transmitter.
First of all, Drak video transmitter provides clean and sharp images great for FPV flight.
This Drak AV transmitter can be used for different FPV racing events that limit maximum output power. The power can be easily changed with the "RF Power" button to toggle between 25, 200, and 600mW to be eligible in those events. It eliminates the hassle to change Tx for different racing. The power is indicated by the LED lights on the up right corner of the LED panel with 3 different size dots.
This product features 40 channels, including those of R band required for a lot of events. By long press of the "Channel" key it can change to A B E F R bands, and short press to change frequencies that is indicated by numbers 1 to 8. The bands are indicated by A B F R LED lights respectively, and band E with all four lights on.
Drak transmitter can accept a wide range of DC input from 6 to 20V, meaning 2S to 4S LiPo can be used directly to power up the unit. It also has two set DC output that can support both 5V and 12V cameras without using an additional BEC.
Package contains a Drak AV transmitter, an antenna, a FPV cable, and a cable for GoPro.
Features:
Adjustable 25, 200, 600mW output power
A B E F R bands and 40 channels, including racing frequencies
DC outputs for both 5V and 12V cameras
Optimized for clean and sharp images
Frequencies (in MHz)
Band CH1 CH2 CH3 CH4 CH5 CH6 CH7 CH8
A 5865 5846 5825 5805 5785 5765 5745 5725
B 5733 5752 5771 5790 5809 5828 5847 5866
E* 5705 5685 5665 5665 5885 5905 5905 5905
F 5740 5760 5780 5800 5820 5840 5860 5880
R 5658 5695 5732 5769 5806 5843 5880 5917
*Note: Four channels in band E are merged to be legally used in USA.
Specifications:
Bands: A B E F R
Frequency: 40 Channels
Output Power: 25, 200, 600mW adjustable
Input Voltage: 7-20V
Input Current: 300mA maxiumun (at 12V)
Antenna Connector: SMA
Dimensions: 38X28X8mm
Weight: 12.5 grams
Features:
Specifications:
Bands: A B E F R
Weight: 12.5 grams
