Flydigital
Hi there, 2nd flight now. 2 time I nearly destroyed my lovely F550.
The reason being the low voltage warning seemed to kick in very early. At 16v when the alert was set for 15.5. I'm assuming the difference is the 'loss'. I add that to the setting to allow it to kick in a little later?
Maybe 15.5 is too high anyway (4s 30c 5000mAh)
So when out in the field I realised that in Manual it ignores the low voltage warning and allows me to play around a bit more - Big mistake! I went totally out of my depth the moment I switch to manual and cartwheeled it through the mud.
Looking forward to my micro quad to arrive to start learning to fly properly.
My main use will probably be GPS for AP work but see that manual could be a lot of fun if you know what you're doing!
