Didn't get much love at rcg so I though the bright sparks here might be able to comment
http://www.rcgroups.com/forums/showthread.php?t=1750660
Applicable to both fixed wing and multirotors.
Given enough info can we predict the failure of a component/system?
Computer hard drives have SMART.
You car has the Engine light.
Not sure what the higher consumer grade UAV have.
MicroDrones etc.
Prop RPM
Motor Vibration
Motor RPM
Motor Temp
Motor Voltage/Current
ESC Temp
ESC Voltage/Current
Ambient Temp/Humidity
Battery Temp
Frame Vibration
Given a base line we should be able to see a component go bad.
Motor bearings,
.increased vibration
.more power for a given rpm
.increased heat for a given watts input
Prop slipping, motor/prop rpm not matching.
ESC,
.more heat for a given watts input
.less rpm for a given watts input
Bad battery,
.more heat for a given watts output
.more voltage drop for a given watts output
Frame,
.combined motor vibration not matching frame vibration
Others?
How much would such a system cost?
The software would be the hard bit, I like open source
Cost of the sensors?
$20 per motor
$15 for the frame
It could be built into the ESC.
This would be a good candidate
http://autoquad.org/esc32/
Possible? Worth it?
MicroDrones etc.
Prop RPM
Motor Vibration
Motor RPM
Motor Temp
ESC Temp
ESC Voltage/Current
Battery Temp
Frame Vibration
Motor bearings,
ESC,
Bad battery,
Frame,
Others?
$20 per motor
$15 for the frame
Possible? Worth it?
