Welcome To DroneVibes
Tx signal lost Wookong
Discussion in 'DJI A2 & WKM flight control systems' started by nileshafilms, Aug 19, 2016.
  1. nileshafilms
    nileshafilms Pankaj Sharma
    38
    0
    1
    Jun 9, 2014
    India
    Posted by nileshafilms, Aug 19, 2016 #1
    Hey guy recently i had weird problem with my system..
    Gryphon x8
    U7 420kv
    18x6.1 cf prop
    Herculas III power board
    Wookong M
    Dji iosd
    Futaba 14sg
    We had around 5 good flights with red epicand ultra prime lens early morning but later when we shifted location as soon as i did take off one blue light blinked on wookong and motors went like dead and system dropped on ground.. luckily frame is safe just propellers and 2 motors damaged because height was not more than 4-5ft..
    But i am very confused about TX Signal lost issue.. can someone help me to find out the issue.. This thing never happened with me and i couldn't find solution anywhere on net..
    I am going to change receiver for now but i hope i could find the issue..
    I think the voltage telemetry plug is loose from inside of receiver.. but not sure if thats the reason for tx signal lost..
    Tags:
  2. DroneTalk
    DroneTalk R/C Expert Staff Member
    470
    42
    11
    Jul 8, 2015
    new jersey
    Posted by DroneTalk, Aug 20, 2016 #2
    A TX signal lost would cause it to go into fail safe and would just land not fall out of the sky.
    Choose one method for your failed-safe function, and the method will be triggered when MC loses the control signal. This could be one of the following situations: 1) Signal lost between transmitter and receiver, e.g. multi-rotor is out of the communication range, or transmitter is down, and so on. 2) One or more connections of A, E, T, R, U channels between MC and receiver loses. If this happens before take-off, motors will not work if you push the throttle stick; if this happens during the flight, LED blue light will flash to warn in addition to the failed-safe method. If Hovering failed-safe method is triggered and U channel is disconnected, multi-rotor will auto land. Here the home point is the position saved by the MC automatically when 6 or more GPS satellites are found (red light blinks once or no blinking) and the first time you push the throttle stick. When switch to Manual or Atti. Mode, MC will disengage enhanced failed-safe mode, you can re-gain control of multi rotor.
  3. Binod singh
    Binod singh New Member
    2
    0
    1
    Feb 2, 2018
    Uk
    Posted by Binod singh, Feb 2, 2018 #3
    Hi, I have a hex with working m and DX8 and Ar8010t receiver.
    It flew couple of times and now it shows Failsafe in WM assistant and motor won't arm.How do I get rid of Failsafe . Help please
  4. dronevibes
    dronevibes Administrator DroneVibes
    28
    1
    1
    Jan 27, 2016
    New Jersey
    Posted by dronevibes, Feb 7, 2018 #4
    Rebind it with the throttle stick low.
Loading...
Share This Page
Loading...
