djw43
I have an almost new TurboAce Cinewing 6HL that took a dip in a freshwater swiming pool. Just began looking it over and I wanted to see if anyone wanted to buy it to fix it up as a project, if not I will take it on myself.
In the assistant motor test, 2 motors don't spin, these two motors have bunt ESC's (two pics below of burnt harness). One other motor stutters in the motor test, haven't further tested that motor or ESC. I think the LED is faulty as I don't see "red" , "white" or "yellow" when I should. I ca get into GPS calibrate mode, blue/ green. I paired it quickly with a 14SG but it did not start. In the assistant the IMU and GPS are getting data and it is varying with movement.
UPDATE!!
IT FLYS!!
youtube video
I have removed 3 bad ESC's and replaced with maytech 45A OPTOs
I have swapped out the BT LED with a working one.
6 - TA-CW6-22: Brushless Motor and Motor Cap for Turbo Ace Cinewing 6
3 - TA-CW6-23: 45A OPTO ESC for Turbo Ace Cinewing 6
3- Maytech 45A OPTO
6 - 15" CF props a few with minor chips
DJI A2 flight computer
DJI iOSD Mk 2
DJI 2.4ghz GS transmitter w canbus cable
futaba R7008SB
folding arms frame
Looking for close to $1425 shipped for the aircraft without gimbal, I have some room.
AV200 w 360 and landing skids, separate price
two of the 4 skids have damage where the landing rods slide in, (they are $20/each wowhobbies )
I have not tested the immersionRC 600mW 5.8ghz video transmitter, I don't have a receiver with that band.
Also not tested the hdmi to AV converter, but I easily can if asked
The futaba R7008SB works as does the BEC
The RSGS stabilizer works
The servos all work and the 360 works as well
the roll and tilt are smooth, no kinks , no bends
no damage at all except for where landing rods attach to skids
this gimbal is nearly new.
AV200 with 360 , skids, futaba R7008SB, hdmi to AV, BEC to 5v, ImmersionRC 600mW Tx
$650 shipped for the whole gimbal setup, just add battery
I can also sell separately, but not yet.
thanks
dave in NJ
UPDATE!!
IT FLYS!!
youtube video
3- Maytech 45A OPTO
DJI iOSD Mk 2
futaba R7008SB
folding arms frame
thanks
dave in NJ
