9 months old in good working condition. $1000 USD. (New is $1490 plus taxes and shipping)
- [h=1]Cube 255[/h] The new Cube 255, like the original, is a camera-top wireless HD video encoder that connects with HDMI cameras. The unit streams via dual-band WiFi, an Ethernet port, or a single 3G/4G USB modem.
The new Cube 255 includes all of the same great features of the original Cube such as a compact aluminum chassis, comprehensive transport protocol support like RTP/RTSP/RTMP/MPEG-TS, and a variety of camera inputs. To bring Cube to the next level, Teradek has added a variety of important new features such as:
[h=2]OLED[/h] Cube’s new OLED enables users to rapidly change and review the settings of their unit in addition to providing real-time feedback for filenames, recording status, and wireless connectivity. No longer are computers or iPads needed for configuration; every feature is a simple click away.
[h=2]Li-ION Battery[/h] Cube’s built-in Li-ION battery will give users up to 2 hours of runtime, which allows for seamless battery swapping or quick broadcasts. The battery can also be charged from an AC adapter or even a suitable external battery such as an Anton Bauer.
[h=2]MIMO Access Point[/h] The new MIMO access point feature greatly improves wireless performance and enables special features such as wireless camera control for devices without a WiFi capability built in, and ensures improved connectivity from an iPad or Android tablets.
[h=2]Audio Output[/h] Cube now comes with a headphone output for immediate audio monitoring.
[h=2]Micro SD[/h] The micro SD slot enables Cube to save on-board proxy recordings in real time. The recorded files (.mov or .mp4) are automatically synced with your proxy server over WiFi or cellular connections.
[h=2]Micro USB[/h] Cube’s micro USB port will charge the new internal battery.
[h=2]CDN Integration[/h] The new Cube also supports dozens of Content Delivery Networks (CDNs), including Ustream, Justin.tv, Livestream, Youtube Live, and many others.
- [h=1]Technical Specs[/h] [h=1]Overview[/h] The Teradek Cube 255 is an H.264 encoder that streams HD video over a/b/g/n WiFi, Ethernet, and cellular.
Video Input: HDMI WiFi: 802.11 a/b/g/n MIMO Video Output: None Mount: Hot Shoe Mount Display: OLED Display Battery: Li-ION Battery Power Input: 2 Pin Lemo Power Power Output: None Storage: microSD Ethernet: 10/100BASE-T USB: USB 2.0 host port Audio: Analog Line or Mic in,Headphone output
[h=2]VIDEO INPUTS[/h]- HD-SDI, SD-SDI: BNC or HDMI
- 1080i 50/59.94/60
- 1080p 23.98/24/25/30
- 720p 23.98/24/50/59.94/60
- 576p
- 480p
- Compression Algorithm: Baseline, Main and High Profile H.264
- Main and Baseline profiles
- Bit Rate: 250 Kbps to 10 Mbps
- Built in Video Scaler and Deinterlacer
- Network Protocols: TCP/IP, UDP, HTTP, DHCP, NTP, SSL, IGMP
- Transport Protocols: RTP, RTSP, RTP over HTTP, MPEG-TS**
- RTMP (Adobe Flash Streaming)
- HTTP Live Streaming
- Point to Point (TCP or UDP), Multiple Unicast (UDP), or Multicast (UDP+IGMP)**
- Audio Compression: AAC-LC, MPEG Layer 2
- Embedded Audio Input
- Analog Line or Mic in, adjustable gain
- Headphone output, adjustable volume
- Dimensions: 2.5"W x 3.5"D x .9"H
- Weight: 8oz
- Feature-rich WebUI for configuration and control
- OLED LCD Display with joystick Navigation buttons
- On/Off and Reset Switch
- Micro SD
- Powered USB 2.0 host port
- Ethernet: 10/100BASE-T
- WiFi: Dual Band 802.11 a/b/g/n MiMO
- USB Modem support**
- 2 Pin Lemo Power input
- Internal Rechargeable Lithium Ion Battery
- USB Charging
- Nominal Power Consumption: 3W
- Nominal Power Consumption while Charging : up to 10W
- Auxiliary Power Input: 6-28V DC
**Optional.
